1. Understanding WhatsApp Broadcasts with Pabbly Connect
WhatsApp broadcasts allow businesses to send promotional messages to multiple contacts simultaneously. With Pabbly Connect, you can streamline this process and reach your customers efficiently.
This feature is perfect for sharing new product launches, discounts, or special offers without manually sending messages to each customer. Using Pabbly Connect, you can set up a broadcast campaign quickly and effectively.
2. Creating Your Broadcast Campaign Using Pabbly Connect
To create a WhatsApp broadcast campaign, first, log into your Pabbly Connect account. Navigate to the broadcast section of Pabbly Chat Flow to manage your campaigns.
- Click on the ‘+ Add Broadcast’ button.
- Select the type of broadcast campaign.
- Enter a name for your campaign.
After naming your campaign, choose your audience by selecting either a contact list or uploading a CSV file. This flexibility allows you to reach a wider audience efficiently through Pabbly Connect.
3. Uploading CSV Files for Contact Management via Pabbly Connect
When uploading a CSV file, ensure it contains customer data in the correct format. A CSV file typically includes first names, last names, and phone numbers, which you can create using Google Sheets or Excel.
To upload your CSV file in Pabbly Connect:
- Select the option to upload a CSV file.
- Choose the file from your device.
- Click on the ‘Insert’ button to add the file.
>Once uploaded, Pabbly Connect allows you to import and use these contacts for your broadcast campaign, making the process seamless and efficient.
4. Selecting Message Types for Your Broadcast Campaign
Once you’ve set up your audience, the next step is to select the message type for your broadcast. Pabbly Connect allows you to choose between pre-approved template messages and regular messages.
For sending a pre-approved template message, follow these steps:
- Enable the option for pre-approved templates.
- Select the appropriate template from your list.
- Add any images or links as needed.
>Using Pabbly Connect to manage these templates ensures compliance with WhatsApp guidelines, allowing for effective communication with your audience.
5. Testing and Scheduling Your Broadcast Campaign with Pabbly Connect
After setting up your message, it’s crucial to test the broadcast before sending it out. In Pabbly Connect, you can enter test contact details to verify that the message is sent correctly.
To schedule your broadcast:
- Select the scheduling option.
- Choose your desired date and time for the broadcast.
- Enable automatic retries for failed messages if desired.
>By utilizing Pabbly Connect, you can ensure that your promotional messages reach your audience at the right time, maximizing engagement and effectiveness.
In this tutorial, we explored how to create WhatsApp broadcast campaigns using Pabbly Connect. By following these steps, businesses can efficiently reach their customers with promotional messages and updates.
