1. Accessing Pabbly Connect to Get Started
To automate the sharing of Facebook leads to WhatsApp, you first need to access Pabbly Connect. Open a new tab and type in the URL for Pabbly Connect.
Once on the landing page, you can either sign up for free or log into your existing account. If you’re new, click on the ‘Sign Up for Free’ button to create your account. This allows you to create up to 100 free automation tasks each month.
After logging into Pabbly Connect, navigate to the dashboard and click on ‘Create Workflow’. This is where you will set up the automation to connect Facebook leads with WhatsApp messages.
  • Click on ‘Create Workflow’
  • Type in your use case, like ‘Connect Facebook Lead Ads with Pabbly Chatflow’
  • Hit ‘Enter’ to create the workflow
Once the workflow is created, you’ll need to set up the trigger for when a new lead is captured from Facebook.
3. Setting Up the Trigger for Facebook Leads
In this step, you’ll configure the trigger in Pabbly Connect to capture new leads from Facebook. Click on the ‘Add Connection’ button and select ‘Connect with Facebook Lead Ads’.
Select your Facebook account and choose the specific page where your leads are generated. This allows Pabbly Connect to capture the lead details directly from your Facebook page.
  • Choose your Facebook page from the dropdown
  • Select the form you want to capture leads from
  • Click ‘Save and Send Test Request’
Once set up, Pabbly Connect will automatically capture lead details as soon as a new lead is generated.
4. Sending WhatsApp Messages with Pabbly Chatflow
After successfully capturing leads, the next step is to send a WhatsApp message using Pabbly Connect and Pabbly Chatflow. To do this, click on ‘Add New Connection’ and connect your Pabbly Chatflow account.
For this, you will need your API token from Pabbly Chatflow. Go to your Chatflow account, navigate to ‘Settings’, and copy the API token. Paste this token back in Pabbly Connect to establish the connection.
  • Add the recipient’s mobile number using mapping
  • Select the template message you want to send
This setup allows Pabbly Connect to automatically send a WhatsApp message to the new lead with your product catalog.
5. Testing the Integration
Now that your workflow is set up, it’s time to test the integration. Use the Meta Lead Ads testing tool to submit a test lead. Fill in the required details and submit the form.
Once the test submission is complete, Pabbly Connect will capture the lead information and send a WhatsApp message with the product catalog. Check your WhatsApp to confirm that the message has been received.
This confirms that your automation is working correctly. You can now automatically send WhatsApp messages to any new leads generated from Facebook, streamlining your marketing efforts.
Integrating Facebook leads with WhatsApp using Pabbly Connect allows for efficient and automated communication with potential customers. The setup process is straightforward, enabling businesses to enhance their marketing strategies.
