To start integrating WhatsApp using Pabbly Connect, you need to access the platform. Simply search for Pabbly Connect in your browser and navigate to the homepage. If you are a new user, click on the “Sign Up for Free” button to create an account.
If you are an existing user, click on the “Sign In” button. After logging in, you can access the dashboard where all your applications are listed. From here, you will be able to access the Pabbly Chatflow application to set up your WhatsApp integration.
2. Setting Up WhatsApp in Pabbly Chatflow
Once you are inside Pabbly Connect, you need to set up your WhatsApp number. This is crucial for sending messages to your customers. To do this, navigate to the Pabbly Chatflow section and click on “Access Now” to enter your dashboard.
  • Locate the WhatsApp integration option.
  • Click on “Add WhatsApp Number” and follow the prompts.
  • Ensure that your number is verified to send messages.
After setting up your WhatsApp number, you can now create message templates that will be used for bulk messaging. This is a significant feature of Pabbly Connect that allows for personalized communication with your customers.
3. Creating a Message Template in Pabbly Chatflow
To send bulk messages via WhatsApp, you need to create a message template. Start by navigating to the template section within Pabbly Connect. Here, you can draft your message, including any media you want to attach.
Make sure to include variables in the template, like the customer’s name, to personalize the messages. You can see a preview of how your message will look once sent. After creating your template, ensure it is approved by the WhatsApp team, as this is a requirement.
  • Draft a message that includes personalized variables.
  • Attach any necessary media files for your message.
  • Submit the template for approval to WhatsApp.
Once your template is approved, you can proceed to set up the broadcast feature in Pabbly Connect to send out your messages to the selected contacts.
4. Sending Broadcast Messages via Pabbly Connect
Now that you have your template ready, it’s time to send out your broadcast messages. In Pabbly Connect, navigate to the broadcast section. Click on “Add Broadcast” to create a new broadcast campaign.
Fill in the details for your broadcast, including the name and the contact list you want to send messages to. You can select contacts from your existing lists or upload a new CSV file with customer data from Google Sheets. This integration allows you to send personalized messages efficiently.
5. Testing and Scheduling Your Broadcast
Before sending your broadcast, it’s crucial to test the message. In Pabbly Connect, you can send a test message to your own WhatsApp number to see how it appears. This step ensures that everything looks correct before the actual broadcast.
If you are satisfied with the test, you can choose to send the broadcast immediately or schedule it for a later time. Select a future date and time for your broadcast to ensure it reaches your audience at the right moment.
After scheduling, Pabbly Connect will handle the rest, sending out your personalized bulk messages to all selected contacts at the designated time.
In this tutorial, we explored how to use Pabbly Connect to integrate WhatsApp with Google Sheets for sending personalized bulk messages. This integration streamlines the process and enhances customer communication effectively.
