To start the integration process, first, access Pabbly Connect by visiting pabbly.com/connect. This platform allows you to automate workflows between different applications seamlessly. If you’re new, sign up for a free account to get started.
Once logged in, you will receive 100 free tasks to test the integration. This is a great way to explore how Pabbly Connect can enhance your business operations without any initial investment.
After accessing Pabbly Connect, navigate to the dashboard and click on the “Create Workflow” option. This is where you will set up the connection between WooCommerce and WhatsApp. Use the quick builder feature to simplify the process.
  • Select “Create Using Quick Builder”.
  • Enter the request: Send WooCommerce order confirmation messages on WhatsApp.
  • Choose the events for WooCommerce to trigger the workflow.
After entering your request, click on “Create” to finalize the workflow. This action will set up the necessary connections within Pabbly Connect to facilitate the integration.
3. Connecting WooCommerce to Pabbly Connect
To connect WooCommerce with Pabbly Connect, you’ll need to set up a webhook. Copy the webhook URL provided in your workflow. Then, go to your WooCommerce store, navigate to the “Settings” section, and scroll down to “Advanced”.
  • Select the “Webhooks” option.
  • Click on “Add Webhook” to create a new webhook.
  • Name the webhook (e.g., New Order Placed) and set the status to active.
  • Set the topic to “Order Created” and paste the webhook URL.
After saving the webhook, WooCommerce will be connected to Pabbly Connect, allowing it to send order details automatically.
4. Sending WhatsApp Confirmations via Pabbly Connect
Now that WooCommerce is connected to Pabbly Connect, you can set up the WhatsApp confirmation message. Go back to your workflow and add the WhatsApp Cloud API as your next action. Click on “Add New Connection” to configure the WhatsApp API.
You’ll need to input your WhatsApp token, phone number ID, and business account ID. This information is essential for establishing a secure connection. Once connected, map the phone number from the previous WooCommerce step to ensure the confirmation goes to the correct customer.
  • Enter the confirmation message, including the customer’s name and order details.
  • Use dynamic fields to personalize the message for each customer.
  • Click “Save and Send Test Request” to check if the setup works correctly.
Upon successful testing, your setup will be complete, and customers will receive automatic WhatsApp confirmations for their orders.
5. Conclusion
This tutorial demonstrates how to use Pabbly Connect to automate WhatsApp order confirmations from WooCommerce. By following these steps, you can streamline your order management process and enhance customer experience.
With Pabbly Connect, you can integrate various applications and automate workflows efficiently, saving time and resources in your business operations.
