To start using Pabbly Connect, navigate to pabbly.com/chatflow in your browser. This will take you to the Pabbly Chat Flow homepage, where you can either sign up for a free trial or log in if you already have an account.
Once you’re logged in, you’ll see the dashboard with various options. To proceed, locate the “All Pabbly Applications” section and click on “Access Now” under Pabbly Chat Flow. This will direct you to the Pabbly Chat Flow dashboard where you can set up your WhatsApp messaging.
2. Setting Up Pabbly Chat Flow for WhatsApp
In this section, you will set up Pabbly Chat Flow to enable WhatsApp messaging. First, ensure that you have linked your WhatsApp number within your Pabbly Chat Flow account. This is crucial for sending messages through the platform.
- Click on the “Broadcast” feature in Pabbly Chat Flow.
- Create a message template if you haven’t done so already.
- Select your desired audience for the broadcast.
By using Pabbly Connect, you can easily manage your WhatsApp broadcasts. Make sure to have your message template ready before proceeding to the broadcast setup.
3. Creating a Broadcast in Pabbly Connect
To create a broadcast, click on the “Create New Broadcast” button in Pabbly Chat Flow. Name your broadcast according to the campaign you are running, such as “New Launch Offer”. This will help you identify the broadcast later.
Next, you will need to select your audience. You can either choose from existing contact lists or upload a CSV file containing your contacts. For instance, if your contacts are stored in Google Sheets, download them as a CSV and upload them here.
- Choose between existing contact lists or upload a CSV file.
- Select the message type (template or regular message).
- Test your broadcast before sending it out.
Utilizing Pabbly Connect ensures that your broadcast reaches the intended audience effectively and efficiently.
4. Scheduling Your Broadcast with Pabbly Connect
After setting up your broadcast, you can choose to send it immediately or schedule it for a later time. If you opt to schedule, make sure to select a future date and time to avoid sending the message immediately.
It’s essential to enable the automatic retry feature for contacts where message delivery fails. This allows Pabbly Connect to automatically resend messages to those contacts without manual intervention, making your broadcasting process seamless.
Once everything is set, click on the “Create Broadcast” button. You will receive a notification confirming that your broadcast has been scheduled successfully. This feature is particularly useful for managing multiple campaigns efficiently.
5. Monitoring Broadcast Performance with Pabbly Connect
After sending or scheduling your broadcast, you can monitor its performance directly from the dashboard. Pabbly Connect allows you to see statistics such as the number of messages sent, delivered, read, and any failures.
This data is crucial for assessing the effectiveness of your campaigns. If certain messages fail to deliver, you can easily reattempt sending them using the resend option available in Pabbly Chat Flow.
Using Pabbly Connect, you can efficiently manage your messaging campaigns, ensuring that you maintain engagement with your customers and improve your outreach efforts.
In this tutorial, we explored how to use Pabbly Connect to integrate Pabbly, Pabbly Chat Flow, and Google Sheets for efficient WhatsApp messaging. By following these steps, you can streamline your communication process and enhance customer engagement.
