To begin integrating Google Ads with Slack, you first need to access Pabbly Connect. If you are a new user, open your browser and navigate to pabbli.com/connect. Here, you can sign up for free and get 100 tasks per month.
Once logged in, you will be directed to the workflow builder of Pabbly Connect. This is where you will set up the automation process. The workflow consists of triggers and actions, which are essential for the integration.
The first step in the integration process is to set up the trigger in Pabbly Connect. Click on the “Add Trigger” button. For the application, select Google Ads, and for the event, choose “New Lead Form Entry”. After this, click on “Connect”.
  • Select Google Ads as the trigger application.
  • Choose the “New Lead Form Entry” event.
  • Click on “Connect” to proceed.
After connecting, you will receive a webhook URL. This URL is crucial as it links Google Ads to Pabbly Connect. Copy this URL and paste it into your Google Ads lead form settings to complete the connection.
3. Configuring Google Ads for Lead Collection
Next, you need to configure your Google Ads campaign to utilize the webhook URL provided by Pabbly Connect. Within the lead form settings, locate the option for lead delivery and paste the webhook URL you copied earlier.
Ensure that you have selected the necessary lead details such as name, email, phone number, and city. This information will be sent to Pabbly Connect whenever a new lead is generated.
4. Setting Up Slack Action in Pabbly Connect
Now that you have configured Google Ads, it’s time to set up the action step in Pabbly Connect. Click on “Add New Action Step” and search for Slack. Select Slack as the action application and choose “Send Channel Message” as the event.
  • Search for Slack and select it as the action application.
  • Select “Send Channel Message” for the event.
  • Connect to your Slack account.
Once connected, you will need to select the channel where the lead notifications will be sent. Ensure that your Slack account is logged in and grant all necessary permissions to Pabbly Connect.
5. Mapping Lead Details and Sending Notifications
In this final step, you will map the lead details from Google Ads to the message format in Slack. Use the mapping feature of Pabbly Connect to insert the lead’s name, phone number, email, and city dynamically into the message.
After mapping, click on “Save and Send Test Request”. This will send a test message to your selected Slack channel. You should see a confirmation that the message has been sent successfully, indicating that the integration is working correctly.
This guide has detailed how to integrate Google Ads with Slack using Pabbly Connect. By following these steps, you can automate lead notifications and streamline communication within your team. Start using Pabbly Connect today to enhance your workflow efficiency!
