To start integrating Google Ads with SMS notifications, access Pabbly Connect by visiting pably.com. Here, you can sign up for a free trial to utilize its features.
After signing up, log in to your Pabbly Connect account and navigate to the Workflow Builder. This interface allows you to create automated workflows that connect different applications seamlessly.
2. Setting Up Google Ads in Pabbly Connect
In this step, you will set up Google Ads as the trigger application in Pabbly Connect. Click on the ‘Add Trigger’ button to select Google Ads from the list.
- Choose ‘New Lead Form Entry’ as the event.
- Click on the ‘Connect’ button to establish a connection.
Once connected, you will receive a Webhook URL. Copy this URL and head over to your Google Ads account to link it, ensuring that your Google Ads is now integrated with Pabbly Connect.
3. Configuring Webhook URL in Google Ads
Integrating the Webhook URL into Google Ads is crucial for sending lead data to Pabbly Connect. In your Google Ads campaign settings, add a lead form and navigate to the lead delivery options.
- Paste the copied Webhook URL in the designated field.
- Click on ‘Send Test Data’ to verify the connection.
Once the test data is sent, return to Pabbly Connect to check if the response is received. This confirms that your Google Ads and Pabbly Connect integration is working correctly.
4. Sending SMS Notifications via Pabbly Connect
Now that you have successfully integrated Google Ads with Pabbly Connect, the next step is to send SMS notifications. Click on the ‘Add Action’ button and select the SMS application you wish to use.
Choose the event ‘Send SMS’ and connect your SMS service account. For instance, if using Twilio, you will need to provide your Account SID, Authorization Token, and other required details.
5. Finalizing the SMS Setup in Pabbly Connect
In the SMS setup, you will create the message body for your SMS. Use placeholders to personalize your messages, such as including the lead’s name. This can be achieved by mapping the fields from the Google Ads lead data.
Finally, click on ‘Save and Send Test Request’ to send a test SMS. Ensure you input a valid phone number to confirm that everything is functioning as expected. Once successful, your automation is ready to go!
Using Pabbly Connect allows you to automate SMS notifications for leads generated from Google Ads. This integration streamlines your communication process, ensuring timely notifications for your leads.
