To begin integrating Shopify with Slack, you need to access Pabbly Connect. Start by visiting the Pabbly Connect website by typing its URL, pabbly.com/connect, in your browser.
Once you reach the homepage, you will see options for signing in or signing up. If you are a new user, click on “Sign Up Free” to create an account. Existing users can simply sign in. Pabbly Connect offers 100 free tasks every month, allowing you to explore its features without any cost.
2. Creating the Workflow in Pabbly Connect
After signing in, navigate to the workflow page in Pabbly Connect. Here, you will set up the automation that connects Shopify with Slack. Begin by clicking on the “Create Workflow” button.
  • Select Shopify as your trigger application.
  • Choose the event as “New Order” to initiate the workflow.
  • Click on the “Connect” button to obtain your webhook URL.
Now, head over to your Shopify account to set up the webhook. This step is crucial as it enables Pabbly Connect to fetch order details automatically. In Shopify, go to Settings, then Notifications, and find the Webhooks section to create a new webhook.
3. Setting Up the Shopify Webhook
In the Shopify Webhooks section, you will create a new webhook that connects to Pabbly Connect. Select the event as “Order Creation” and paste the webhook URL you obtained earlier.
After saving the webhook, return to Pabbly Connect. You should see that it is waiting for a response from Shopify. To test this setup, place a new order in your Shopify store.
4. Sending Notifications to Slack
After placing a test order, check Pabbly Connect for the order details. Once the data is received, you can set up Slack to notify your team about the new order.
  • Select Slack as your action application in Pabbly Connect.
  • Choose “Send Channel Message” as the action event.
  • Connect to your Slack account by entering your token.
Map the order details received from Shopify to the message fields in Slack. This will ensure that every time a new order is placed, your team receives a notification with all relevant details, streamlining your workflow.
5. Conclusion
In this tutorial, we explored how to integrate Shopify with Slack using Pabbly Connect. By following these steps, you can automate order notifications and enhance your business workflow.
Utilizing Pabbly Connect not only saves time but ensures your team is always updated about new orders, making your operations smoother and more efficient.
