To start integrating WhatsApp with Pabbly Connect, first visit the Pabbly Connect website. Here, you can sign up for a free account that provides you with 100 free tasks to test your automations. This allows you to explore the features without any upfront cost.
After signing up, log into your Pabbly Connect account. You will be directed to the dashboard where you can create workflows. This is where the integration process begins, allowing you to link WhatsApp with your lead generation tools seamlessly.
Once logged in, navigate to the “Create Workflow” option on the dashboard. This feature allows you to set up automated tasks easily. For our integration, select the “Create Using AI” option to leverage Pabbly Connect’s AI capabilities.
- Select the trigger application: Pabbly Chatflow.
- Choose the event: New Lead Generated.
- Set up the action to send a WhatsApp message.
After selecting the trigger, approve and create the workflow. This step ensures that every time a new lead is generated, a WhatsApp message will be sent automatically, streamlining your communication process.
3. Setting Up Triggers in Pabbly Connect
To set up the triggers in Pabbly Connect, you will need to provide a webhook URL to your account manager. This URL will capture the lead information from your lead generation tool. Once the URL is added, you will receive responses directly into Pabbly Connect.
The captured response will include essential details such as the lead’s name, phone number, and message. This data is crucial for personalizing your WhatsApp messages, making your outreach more effective.
After capturing the lead information, it’s time to send a WhatsApp message. In the Pabbly Connect workflow, connect to Pabbly Chatflow to manage your WhatsApp communications. Click on the connect button and enter your API key from the Pabbly Chatflow settings.
- Enter the recipient’s phone number dynamically using the mapped data.
- Choose the WhatsApp message template you created earlier.
- Specify the header type and media URL if required.
Once all fields are filled, click on the “Save and Send Test Request” button. This will send a test message to ensure everything is working correctly, providing you with immediate feedback on the integration.
5. Conclusion
Integrating WhatsApp with Pabbly Connect offers a powerful solution for automating your messaging process. By following these steps, you can efficiently manage communications with your real estate leads, enhancing your business operations.
This tutorial highlights the ease of use and effectiveness of Pabbly Connect in setting up automated workflows. Start using Pabbly Connect today to streamline your messaging and improve lead engagement.
