To begin the integration process, you need to access Pabbly Connect. Start by opening your browser and navigating to pabbl.com/connect. This platform is essential for connecting various applications, including Notion and Tyform.
If you are new to Pabbly Connect, click on the “Sign up for free” option in the top right corner. This allows you to explore the platform with 100 free tasks each month, which is perfect for testing your integrations.
Once logged in, you will be directed to the workflow builder of Pabbly Connect. This is where you will set up your automation. Click on the “Add Trigger” button to start the process. A trigger is an event that starts your workflow.
- Select “Form Builder” as your trigger application.
- Choose the event as “New Entry”.
- Connect your Tyform account by adding a new connection.
After selecting your form, click on “Save and Send Test Request” to ensure everything is set up correctly. This step is crucial as it verifies the connection between Pabbly Connect and Tyform.
3. Submitting the Form via Tyform
Now that your workflow is set up, you can proceed to submit a form through Tyform. Open the form link in a new tab and fill in the required details. For instance, enter a name, mobile number, and city before clicking “Submit”.
Once you submit the form, Pabbly Connect will capture the response. You should see the data reflected in your workflow within a few seconds, confirming that the integration is functioning correctly.
4. Adding Notion as an Action in Pabbly Connect
Next, you will add Notion as an action step in your workflow. Click on “Add New Action Step” and search for Notion. Select it as your action application to proceed.
- Choose the event as “Create Database Item”.
- Connect your Notion account by adding a new connection.
- Grant permissions for Pabbly Connect to access your Notion pages.
After setting up the connection, you will need to map the fields from your Tyform submission to the Notion database. This mapping allows the data to flow seamlessly from Tyform to Notion, ensuring all entries are recorded automatically.
5. Finalizing Your Automation in Pabbly Connect
With everything set up, you can finalize your automation. Click on “Save and Send Test Request” to ensure that the data from Tyform is correctly added to your Notion database. You should receive a confirmation message indicating that a new database item has been created.
Now, every time a new form submission is received, Pabbly Connect will automatically add the details to your Notion database without any manual intervention. This automation saves time and reduces the risk of errors in data entry.
In this tutorial, we explored how to automate data entry between Notion and Tyform using Pabbly Connect. By following the steps outlined, you can streamline your workflow and enhance productivity.
