1. Accessing Pabbly Connect to Send Discount Offers
To send discount offers using Pabbly Connect, start by visiting the Pabbly Chartflow homepage. This platform allows you to integrate various applications seamlessly. If you’re new, click on ‘Sign up for free’ to create an account, or log in if you already have one.
Once logged in, navigate to the Pabbly Chatflow dashboard. Here, ensure that you have connected your WhatsApp number to utilize the broadcasting feature effectively. Pabbly Connect acts as the central hub for managing your WhatsApp communications.
2. Creating a WhatsApp Message Template in Pabbly Connect
Before sending out bulk messages, you need to create a message template within Pabbly Chatflow. This template will include personalized variables for each customer, making your messages more engaging. A well-structured template can significantly enhance your outreach.
  • Navigate to the ‘Template’ section in Pabbly Chatflow.
  • Create a new template and include dynamic variables for personalization.
  • Ensure your template is approved by Meta before use.
Once your template is ready, you can easily access it when setting up your broadcast. The use of variables ensures that each customer receives a unique message, which is crucial for effective communication.
3. Setting Up a Broadcast Campaign with Pabbly Connect
Next, you will set up a broadcast campaign using Pabbly Connect. Start by selecting the ‘Add Broadcast’ button in the dashboard. This feature allows you to send messages to multiple contacts at once, saving you time and effort.
In the broadcast setup, choose ‘Broadcast Campaign’ as the type and name your campaign, for example, “New Discount Offer”. Then, you can either select an existing contact list or upload a CSV file with customer details. Pabbly Connect simplifies this process by providing options to refine your audience.
  • Select your audience from the existing contact list or upload a CSV file.
  • Refine your audience by excluding specific contacts if necessary.
  • Choose between a pre-approved template message or a regular message.
After setting your audience, select the message type and choose your previously created template. This step ensures that your discount offers are sent out efficiently and effectively through Pabbly Connect.
4. Testing and Scheduling Your WhatsApp Broadcast
Before sending your broadcast, it’s crucial to test your message. Pabbly Connect allows you to send a test message to your WhatsApp number. This step ensures that everything is functioning correctly and that your message appears as intended.
To test, enter your contact name and number, then click on ‘Send Test Message’. Once you receive the test message, you can review it for any adjustments. After successful testing, you can schedule your broadcast for a later date or send it immediately.
  • Select whether to send the message immediately or schedule it for later.
  • If scheduling, ensure you set a future date and time.
  • Enable automatic retries for failed contacts if desired.
Once scheduled, Pabbly Connect will handle the delivery of your broadcast, ensuring that your discount offers reach your customers at the right time.
5. Monitoring Broadcast Performance with Pabbly Connect
After sending your broadcast, monitoring its performance is essential. Pabbly Connect provides detailed analytics on your broadcast’s success. You can track metrics such as delivered, read, and failed messages.
This data allows you to refine future campaigns and improve your outreach strategies. If any messages fail to send, Pabbly Connect offers options to resend them easily.
  • View statistics on sent, delivered, read, and failed messages.
  • Use the analytics to improve your future campaigns.
  • Resend failed messages to ensure all customers receive their offers.
By leveraging Pabbly Connect’s analytics, you can make data-driven decisions that enhance your marketing efforts and customer engagement.
In conclusion, using Pabbly Connect to send discount offers via WhatsApp Broadcast is an efficient way to engage customers. With personalized messages and robust analytics, you can optimize your outreach effectively.
