1. Introduction to Pabbly Connect for Automation
Pabbly Connect is a powerful tool that enables automation between various applications. In this tutorial, we will use Pabbly Connect to automate notifications from Google Blogger to Discord. This integration will help notify your audience about new blog posts instantly.
By setting up this automation, you can keep your followers updated without manual intervention. This is particularly useful for bloggers who want to maintain an active presence on social media platforms.
2. Accessing Pabbly Connect
To start using Pabbly Connect, visit the Pabbly Connect website at pabby.com/connect. Here, you can sign up for a free account or log in if you already have one. New users get 100 free tasks every month, allowing them to explore the platform’s capabilities.
After logging in, you will land on the dashboard. From here, you can begin creating your automation workflow. Click on the “Create Workflow” button to start setting up the integration.
3. Creating a Workflow for Google Blogger and Discord
In this section, we will create a workflow that connects Google Blogger with Discord using Pabbly Connect. First, select the trigger application, which is Google Blogger in this case. Choose the event “New Post Added” to set the trigger.
  • Select Google Blogger as the trigger application.
  • Choose “New Post Added” as the trigger event.
  • Connect your Google account to allow Pabbly Connect to access your Blogger posts.
Once the trigger is set, proceed to the action application. Select Discord and choose the action “Send Channel Message”. This will allow you to send notifications to your Discord channel whenever a new blog post is published.
4. Configuring Google Blogger and Discord Connections
To finalize the integration, you need to set up connections for both Google Blogger and Discord using Pabbly Connect. For Google Blogger, select the blog you want to monitor for new posts. Make sure to choose only live posts to receive notifications about.
Next, configure the Discord connection by entering the webhook URL. This URL is generated in your Discord channel settings. Copy the URL and paste it into the Pabbly Connect action setup.
  • Select the blog from your Google Blogger account.
  • Set the blog status to only live posts.
  • Paste the Discord webhook URL into the action setup.
After entering all necessary details, you can test the integration to ensure everything is working correctly. Pabbly Connect will fetch the latest blog post and prepare to send the notification to Discord.
5. Testing and Finalizing the Integration
Once you have configured the connections, it’s time to test your integration using Pabbly Connect. Create a new blog post in Google Blogger and publish it. After publishing, go back to Pabbly Connect and send a test request to check if the notification is sent to your Discord channel.
If everything is set up correctly, you will receive a message in Discord confirming that a new blog post is live, along with the title and URL of the blog. This confirms that your automation is successfully working!
This integration not only saves time but also keeps your audience engaged with timely updates about new content. With Pabbly Connect, you can easily manage multiple integrations and automate your workflow seamlessly.
In this tutorial, we explored how to automate notifications from Google Blogger to Discord using Pabbly Connect. This integration ensures that your audience is always informed about new blog posts, enhancing engagement and visibility.
