To start sending bulk WhatsApp messages, you need to access Pabbly Connect. This platform allows seamless integration between WhatsApp and Google Sheets. Simply visit the Pabbly Connect website at www.pabbly.com/connect and sign up for a free account to get started.
If you are a new user, signing up will grant you 100 free tasks to test the features. Once logged in, you can create workflows that connect various applications, including WhatsApp and Google Sheets. This makes it easy to automate your messaging process.
After logging into Pabbly Connect, navigate to your dashboard to create a new workflow. Click on the “Create Workflow” button and choose the option to create using the quick builder. This tool simplifies the setup process.
For this integration, you’ll want to connect Google Sheets with WhatsApp. Follow these steps to set up your workflow:
- Click on “Create Workflow”.
- Select “Google Sheets” as your trigger application.
- Choose the “New Row” trigger event.
- Connect your Google Sheets account to Pabbly Connect.
Once the connection is established, you can set up the necessary parameters for your workflow. This will allow you to send messages to all the contacts in your Google Sheets whenever a new entry is added.
3. Setting Up Google Sheets for WhatsApp Messages
To effectively send messages, you need to configure your Google Sheets to work with Pabbly Connect. Start by opening your Google Sheets and navigating to the Extensions menu. Here, you will need to install the Pabbly Connect Webhooks add-on.
After installation, refresh your spreadsheet and go to the “Pabbly Initiate Webhooks” option. Here’s how to set it up:
- Paste the webhook URL provided by Pabbly Connect.
- Specify the trigger column (e.g., Column D).
- Click on the “Submit” button to save your settings.
With this setup, every time a new contact is added to your Google Sheets, it will trigger a message to be sent via WhatsApp through Pabbly Connect. This ensures efficient bulk messaging without the risk of being blocked by Meta.
With your Google Sheets configured, you can now send WhatsApp messages to your contacts. In Pabbly Connect, navigate to the workflow you created and set up the action to send messages via WhatsApp.
Here’s how to map the data and send the messages:
- Select the WhatsApp action event in Pabbly Connect.
- Map the recipient’s phone number from your Google Sheets data.
- Choose the message template you created for WhatsApp.
Once you have mapped all the necessary fields, click on the “Send Test Request” button. If successful, you will receive a confirmation that the message was sent, demonstrating that your integration is working perfectly.
5. Bulk Messaging with Pabbly Connect
To send bulk messages to all contacts in Google Sheets, use the “Send All Data” option in the Pabbly Connect workflow. This feature allows you to send a message to multiple contacts at once, making your marketing efforts much more efficient.
Follow these steps to execute bulk messaging:
- Go to Extensions in Google Sheets and select “Pabbly Webhooks”.
- Click on the “Send All Data” option.
- Monitor the process as messages are sent to all contacts in your sheet.
Once the process is complete, you will see multiple messages sent to your WhatsApp, confirming that the bulk messaging was successful. This method ensures that you can reach out to all your leads without the risk of getting blocked by Meta, thanks to the approved message templates used.
In summary, using Pabbly Connect to send bulk WhatsApp messages through Google Sheets is a straightforward process. By following the steps outlined in this tutorial, you can automate your messaging effectively and reach your audience without any issues. With Pabbly Connect, you can streamline your marketing efforts and enhance your communication strategy.
