1. Accessing Pabbly Connect to Start Integration
To begin integrating WhatsApp, Google, and YouTube, you first need to access Pabbly Connect. Open your browser and navigate to pabbly.com.
If you are a new user, click on the “Sign Up for Free” button to create your account. Existing users can simply log in to access the Pabbly apps dashboard, where you can find all the applications offered by Pabbly.
2. Setting Up WhatsApp Connection in Pabbly Connect
Once you are in the Pabbly dashboard, select Pabbly Connect to set up your WhatsApp connection. If you haven’t connected your WhatsApp number yet, follow the provided tutorial to do so.
  • Select “Access Now” under Pabbly Connect.
  • Navigate to the Broadcast section.
  • Choose a message template or create a new one.
After setting up your WhatsApp connection, you can start creating your broadcast messages. Ensure that your message template is approved by WhatsApp for successful delivery.
3. Creating Broadcast Messages for Multiple Customers
In this section, you will learn how to create a broadcast message using Pabbly Connect. Click on the “Add Broadcast” button to start the process. You need to select the broadcast type as “Broadcast Campaign”.
  • Name your broadcast, for example, “New End of Season Sale”.
  • Select your audience from existing contact lists or upload a CSV file if necessary.
  • Choose a message type: pre-approved template or regular message.
This process allows you to send the same WhatsApp message to multiple customers simultaneously, saving you time and effort.
4. Scheduling Broadcasts Using Pabbly Connect
After creating your broadcast, you can schedule it using Pabbly Connect. You can choose to send messages immediately or schedule them for a later date by selecting the appropriate date and time.
Ensure to select a future date and time to avoid sending messages immediately. You can also enable the automatic retry option for failed contacts, allowing you to resend messages without manual intervention.
5. Testing and Finalizing Your Broadcasts
Before sending out your broadcast, it is crucial to test it. Use the testing feature in Pabbly Connect to send a test message to your own WhatsApp number. This ensures that your message appears correctly.
Once tested, finalize your broadcast settings and click on “Add Broadcast” to complete the setup. You can monitor the status of sent messages and any that may have failed.
In this tutorial, we explored how to use Pabbly Connect to integrate WhatsApp with Google and YouTube, allowing you to send bulk messages efficiently. With Pabbly Connect, you can streamline your communication process effortlessly.
