1. Getting Started with Pabbly Connect for WhatsApp Automation
To send bulk WhatsApp messages, you must first access Pabbly Connect. Start by navigating to the Pabbly Chartflow dashboard. If you are a new user, visit pabbl.com/chartflow to sign up for a free account.
Once logged in, you will have access to 100 free credits every month for sending WhatsApp messages. This allows you to test and explore the features of Pabbly Connect before committing to a subscription plan.
2. Adding Your WhatsApp Number in Pabbly Chartflow
After logging into Pabbly Connect, ensure that your WhatsApp number is added to the platform. This is crucial for sending messages. You can find the ‘Add WhatsApp Number’ button on the dashboard.
- Click on ‘Add WhatsApp Number’ to input your details.
- Follow the on-screen instructions to complete the addition.
- Make sure your number is verified to use the messaging features.
Once your WhatsApp number is added, you can proceed to use the broadcast feature to send messages to your contacts.
3. Creating a Broadcast Using Pabbly Connect
To initiate a broadcast, navigate to the broadcast feature within Pabbly Connect. Click on the ‘Add Broadcast’ button to start creating your message campaign.
Here’s how to set it up:
- Select the broadcast type as ‘Broadcast Campaign’.
- Enter a name for your broadcast, such as ‘30% Off’.
- Choose the contact list you wish to send the message to.
After setting up the broadcast, you can select the type of message you want to send, either a pre-approved template or a regular message. Ensure to follow the template guidelines for WhatsApp messaging.
4. Sending and Scheduling Your Broadcast in Pabbly Connect
Once you have created your broadcast in Pabbly Connect, it’s time to test and send it. You can send a test message to verify that everything is set up correctly.
To send or schedule your broadcast:
- Click on ‘Send Test Message’ to check if the broadcast works as intended.
- To schedule, select ‘Schedule for Later’ and set your desired date and time.
This allows you to manage your messaging campaigns effectively, ensuring timely delivery to your audience. Monitor the status of your messages directly within the Pabbly Connect dashboard.
5. Tracking Message Delivery Status with Pabbly Connect
After your broadcast is sent, Pabbly Connect provides tools to track the delivery status of your messages. You can view how many messages were sent, delivered, read, or failed.
For effective tracking:
- Check the ‘View Stats’ section for detailed analytics.
- Identify failed messages and resend them easily.
This feature ensures that your messaging campaigns are efficient and allows you to refine your approach based on performance metrics. Using Pabbly Connect means you can automate your WhatsApp marketing seamlessly.
In conclusion, using Pabbly Connect to send bulk WhatsApp messages is a straightforward process. This tutorial has equipped you with the necessary steps to automate your messaging effectively, enhancing your marketing strategies.
