To start using Pabbly Connect, you first need to navigate to the Pabbly website. Here, you can either sign in if you are an existing user or click on “Sign Up Free” to create a new account. This platform is essential for integrating WhatsApp with other applications.
Once logged in, you will see various Pabbly applications. Click on Pabbly Connect to access its dashboard, where you can set up your automation workflows. This is where the integration magic happens.
2. Setting Up WhatsApp Broadcast with Pabbly Connect
In this section, we will set up a WhatsApp broadcast through Pabbly Connect. Begin by navigating to the “Broadcast” section within your Pabbly Connect dashboard. Here, you can create a new broadcast for sending messages to your customers.
- Click on “Set Broadcast” to start the process.
- Select the broadcast type from the dropdown menu.
- Name your broadcast appropriately, such as “Bulk Message”.
After naming your broadcast, you will need to upload your contact list. Ensure that the contacts are imported from your Google Sheets or any other relevant source. This is crucial for sending personalized messages to each customer.
3. Creating a Message Template in Pabbly Connect
Now, let’s create a message template that will be used in your WhatsApp broadcasts. Within the Pabbly Connect dashboard, go to the “Template” section. Here, you can manage your message templates effectively.
To create a new template, click on “Add Template”. You will need to fill out the template details, including:
- Template Name: Choose a relevant name for your template.
- Message Content: Draft the message you want to send, using variables for personalization.
Once your template is created, ensure it is approved by WhatsApp. You can check the status in the same section. This approval is necessary for sending bulk messages without getting flagged as spam.
4. Sending Messages via Pabbly Connect
With your broadcast and message template set up, it’s time to send your messages. Navigate back to the “Broadcast” section and select the broadcast you created earlier. Here, you will find the option to send your message.
Before sending it to all contacts, it is recommended to test the broadcast by sending it to your WhatsApp number. Click on “Send Test Message” and enter your details. Once confirmed, you can proceed to send it to your entire contact list.
5. Scheduling Your WhatsApp Broadcasts Using Pabbly Connect
Finally, you can schedule your WhatsApp broadcasts for future dates. In the broadcast settings, choose the option to schedule your message. Select the date and time for when you want the message to be sent.
Make sure to select a future date; otherwise, the message will be sent immediately. Once scheduled, click on “Add Broadcast” to finalize your settings. This will help you automate your communication effectively.
Using Pabbly Connect for integrating WhatsApp with Google Sheets and other applications simplifies the process of sending bulk messages. By following these steps, you can enhance your customer communication efficiently.
