To integrate WhatsApp using Pabbly Connect, start by visiting pabbly.com and signing up for a free account. This allows you to access the features necessary for sending bulk WhatsApp messages.
Once logged in, navigate to the dashboard of Pabbly Connect. Here, you can set up your WhatsApp account by following these initial steps:
  • Create a new account on Pabbly Connect.
  • Access the WhatsApp management tool within Pabbly Connect.
  • Add your WhatsApp number for messaging.
This setup is crucial as it ensures your number is safe and compliant with WhatsApp’s policies, allowing you to send messages without the risk of being blocked.
2. Creating a Contact List in Pabbly Connect
After setting up your account, the next step in Pabbly Connect is to create a contact list. This list will include all the customers you want to send messages to. You can do this by navigating to the “Contacts” section.
Here’s how to create your contact list:
  • Go to the “Contacts” section in Pabbly Connect.
  • Add all customer phone numbers to this list.
  • Ensure that all numbers are formatted correctly for WhatsApp.
Creating a well-organized contact list is essential for effective bulk messaging, as it allows you to manage and target your audience efficiently.
3. Creating a Message Template in Pabbly Connect
Next, you need to create a message template in Pabbly Connect. This template will be the body of the message you wish to send to your contacts. Navigate to the “Templates” section to begin.
Follow these steps to create your template:
  • Click on “Add Template” in the Templates section.
  • Select the appropriate category for your template.
  • Input the message body, including any images or variables you wish to include.
Once your template is created, it will be submitted for approval by Meta. After approval, you can use this template for bulk messaging through Pabbly Connect.
4. Broadcasting Messages via Pabbly Connect
With your contact list and message template ready, you can now broadcast messages using Pabbly Connect. Navigate to the “Broadcast” section to initiate this process.
Here’s how to broadcast your messages:
  • Click on “Add Broadcast” to start a new campaign.
  • Select your contact list and message template.
  • Schedule the broadcast for immediate or later delivery.
This step allows you to reach thousands of customers efficiently, ensuring your promotional messages are sent out without hassle.
Using Pabbly Connect allows businesses to effectively integrate WhatsApp for bulk messaging. By following these steps, you can promote your business seamlessly and safely.
