To send bulk WhatsApp messages, you first need to set up Pabbly Connect. Start by visiting pabbly.com/connect and create an account if you haven’t already. This platform will allow you to automate your WhatsApp messaging process seamlessly.
Once logged in, you can create a new workflow. This workflow will connect your Google Sheets with WhatsApp through Pabbly Connect. By doing so, you can send personalized messages to multiple contacts without the risk of getting blocked.
2. Connecting Google Sheets to Pabbly Connect
Next, you need to connect Google Sheets to Pabbly Connect. This involves creating a trigger that activates when a new row is added. Start by selecting Google Sheets as your trigger application within the workflow.
  • Choose “New Spreadsheet Row” as the trigger event.
  • Open your Google Sheets, go to Extensions, then Add-ons, and search for Pabbly Connect Webhooks.
After installing, return to your spreadsheet and refresh it. You’ll see the Pabbly Connect option. Click on it to set up the Webhook URL in the initial setup dialog. Ensure you specify the trigger column where your contact details are stored.
3. Configuring WhatsApp Messaging via Pabbly Chat Flow
After setting up Google Sheets, the next step is to configure WhatsApp messaging using Pabbly Chat Flow. This action step will allow you to send messages through WhatsApp when new rows are added to your Google Sheets.
In your workflow, select Pabbly Chat Flow as your action application. You will need to connect it by providing your API token from your Pabbly Chat Flow account settings. This token is essential for authenticating your requests.
  • Select the option to add a new connection.
  • Paste your API token into the connection setup.
  • Map the recipient’s WhatsApp number from the previous step.
Once mapped, you can customize your WhatsApp message. This personalization is crucial for effective communication with your contacts. After setting everything up, click on “Save and Send Test Request” to ensure everything is working correctly.
4. Sending Bulk WhatsApp Messages
Now that your setup is complete, it’s time to send bulk WhatsApp messages using Pabbly Connect. By clicking the “Send All Data” button in your Google Sheets, you can initiate the process. This will trigger the workflow you’ve created, sending messages to all contacts listed.
You should see messages being delivered to each contact one by one. This is facilitated by Pabbly Connect, ensuring that each message is sent safely and efficiently without risking your number being blocked.
For example, if your Google Sheets contains multiple contacts like Aarav Mehta, Ananya Sharma, and Rohan Kapoor, each will receive their respective promotional messages through WhatsApp as per the entries in your sheet.
5. Conclusion: Mastering Bulk WhatsApp Messaging with Pabbly Connect
In conclusion, using Pabbly Connect to send bulk WhatsApp messages is a straightforward process. By integrating Google Sheets and Pabbly Chat Flow, you can automate your messaging campaigns effectively.
This method not only saves time but also ensures that your messages reach your audience without the risk of getting blocked. With just a few simple steps, you can master bulk messaging for your business needs.
Start using Pabbly Connect today to enhance your WhatsApp marketing strategy!
