To start using Pabbly Chatflow, open your web browser and navigate to pav.com/chartflow. This will take you to the homepage of Pabbly Chatflow, where you can sign up or log in. If you are a new user, click on ‘Sign up for free’ to create your account.
Once logged in, you will see the Pabbly apps window. Click on ‘Access Now’ under Pabbly Chatflow to reach the dashboard. Here, you can connect your WhatsApp number. For detailed instructions on connecting your WhatsApp, refer to the tutorials available on the Pabbly YouTube channel.
2. Creating a WhatsApp Template in Pabbly Chatflow
Before sending bulk messages, you need a WhatsApp template. This template will allow you to send personalized messages through Pabbly Chatflow. Make sure your template is approved by Meta for bulk messaging.
To create a template, navigate to the template section in Pabbly Chatflow. Here’s how to set it up:
  • Select the template option.
  • Fill in the required fields with your message content.
  • Submit for approval to Meta.
Once your template is approved, you can proceed to the broadcast section in Pabbly Chatflow to utilize this template for sending messages.
3. Setting Up Your WhatsApp Broadcast in Pabbly Chatflow
To initiate a WhatsApp broadcast, go to the broadcast section in Pabbly Chatflow. Click on the ‘Start Broadcast’ button, which will direct you to the WhatsApp broadcast window. Choose ‘Broadcast Campaign’ from the drop-down menu for the broadcast type.
Next, give your broadcast a name, such as “New Skin Care Test”. Then, select the contact list you want to send messages to. If you have customer data in Google Sheets, download it in CSV format and upload it to Pabbly Chatflow. Here’s how:
  • Click on ‘Add Contact’ to upload the CSV file.
  • Select the existing list or create a new one.
This will allow you to manage your contacts efficiently within Pabbly Chatflow.
4. Sending Personalized Messages via Pabbly Chatflow
Once your broadcast is set up, it’s time to send personalized messages. In Pabbly Chatflow, you can choose between a pre-approved template message or a regular message. For this tutorial, select the pre-approved template you created earlier.
To personalize the message, use variables for names or other details. Access the contact custom fields under settings to add dynamic content. Here’s how:
  • Select the template and insert variables where needed.
  • Test your message by sending a sample to your WhatsApp number.
After testing, you can schedule your broadcast or send it immediately, ensuring your messages reach your audience effectively through Pabbly Chatflow.
5. Monitoring Broadcast Results in Pabbly Chatflow
After sending your WhatsApp broadcast, it’s crucial to monitor its performance. In Pabbly Chatflow, you can view the statistics of your broadcast, including sent, delivered, read, and failed messages. This data helps you refine future broadcasts.
To access the stats, navigate to the broadcast section and select your broadcast. You’ll see detailed analytics that provide insights into the effectiveness of your messaging. Additionally, you can resend messages to failed contacts using the resend option, ensuring no customer is left out.
Using Pabbly Chatflow for WhatsApp broadcasts streamlines your communication process. By following the steps outlined, you can effectively send personalized messages to your customers, enhancing engagement and satisfaction. Start leveraging Pabbly Chatflow today to optimize your messaging strategy.
