1. Accessing Pabbly Chatflow for Automation
To automate webinar reminders, first, you need to access Pabbly Chatflow. If you are a new user, open a new tab and search for pabbl.com/chartflow. This will take you to the landing page of Pabbly Chatflow.
Once there, click on the “Sign Up for Free” button located in the top right corner. This allows you to try Pabbly Chatflow for free, enabling you to send up to 100 webinar reminders via WhatsApp. If you decide to continue using it, you can purchase a subscription plan later.
2. Adding Your WhatsApp Number in Pabbly Chatflow
Before sending any messages, you must add your WhatsApp number to Pabbly Chatflow. Navigate to the settings section, where you can input your WhatsApp number. This step is crucial for ensuring that your messages are sent correctly.
  • Go to the settings section in Pabbly Chatflow.
  • Enter your WhatsApp number in the designated field.
  • Save the changes to confirm your number.
Once your WhatsApp number is added, you are ready to create your broadcast campaign. This setup allows you to automate the sending of messages to your contacts efficiently.
3. Creating a Broadcast Campaign in Pabbly Chatflow
To create a broadcast campaign, go to the “Broadcast” section in Pabbly Chatflow. Click on the “Add Broadcast” button to start setting up your campaign. Choose the “Broadcast Campaign” option from the available types.
Next, you will need to name your broadcast. For example, you can name it “Webinar Reminder.” After naming, select the contact list to whom you wish to send the WhatsApp messages. You can create a new contact list or choose from existing ones.
  • Select the contact list for your broadcast.
  • You can choose multiple lists if needed.
  • Refine your audience by excluding specific contacts if necessary.
This feature allows you to tailor your message delivery effectively, ensuring that your webinar reminders reach the right participants.
4. Scheduling Webinar Reminders with Pabbly Chatflow
After selecting your audience, you can choose the message type in Pabbly Chatflow. You have the option to use a pre-approved template or a regular message. If you choose the regular message, you can directly enter the text of the reminder.
To format the message, use stars to bold specific text. For example, if your message includes the webinar details, format it accordingly. You can also enable link previews if you want to include any links in your message.
  • Enter the message text and format it as needed.
  • Test the message by sending it to yourself before broadcasting.
  • Schedule the broadcast for a specific time before the webinar.
By scheduling the message, you ensure that participants receive their reminders exactly one hour before the webinar starts, effectively reducing no-shows.
5. Tracking Message Stats in Pabbly Chatflow
Once your broadcast is scheduled, Pabbly Chatflow allows you to track the performance of your messages. You can view statistics such as how many messages were sent, delivered, read, or pending. This feature is essential for understanding the effectiveness of your campaigns.
To view the stats, navigate to the “Stats” section in Pabbly Chatflow. Here, you can analyze the success of your webinar reminders and make adjustments for future campaigns as needed.
Using these insights, you can optimize your messaging strategy and improve engagement for upcoming webinars. This ensures that your reminders are effective and that participants are well-informed.
In this tutorial, we explored how to automate webinar reminders using Pabbly Chatflow and WhatsApp. By following the steps outlined, you can efficiently manage your reminders and enhance participant engagement.
