1. Introduction to Pabbly Connect for SMS Integration
Pabbly Connect is a powerful integration platform that allows you to automate workflows easily. In this tutorial, we will use Pabbly Connect to send bulk SMS messages from Google Sheets to your customers via Twilio.
To begin, access Pabbly Connect by visiting their website, where you can sign up for free. This will allow you to explore its features and test sending SMS without any initial cost.
2. Setting Up Google Sheets with Pabbly Connect
First, you need to prepare your Google Sheets with the customer data you wish to send SMS messages to. This is where Pabbly Connect comes into play. You will integrate Google Sheets with Pabbly Connect to automate the SMS sending process.
Follow these steps to set up the integration:
- Open Google Sheets and create a new spreadsheet with your customer data.
- Go to Extensions > Add-ons > Get Add-ons.
- Search for “Pabbly Connect Webhooks” and install it.
- Refresh your spreadsheet to see the new option from Pabbly Connect.
Once the add-on is installed, you will set up the webhook URL provided by Pabbly Connect. This URL will be used to trigger SMS messages whenever new data is added to your Google Sheets.
3. Configuring Pabbly Connect Webhook
With your Google Sheets set up, the next step is to configure the webhook in Pabbly Connect. This is crucial for connecting your Google Sheets data to the SMS service.
Here’s how to configure it:
- In Google Sheets, go to the Pabbly Connect Webhooks option and select “Initial Setup”.
- Paste the webhook URL from Pabbly Connect into the designated field.
- Enter the trigger column where your data ends, for example, the city column.
- Click on the “Submit” button to save the configuration.
After submitting, you will see a confirmation message indicating that your setup was successful. This means your Google Sheets is now linked with Pabbly Connect and ready to send SMS messages.
4. Sending SMS with Twilio via Pabbly Connect
Now that you have configured Pabbly Connect with Google Sheets, it’s time to set up Twilio to send SMS messages. Twilio is an SMS service that integrates seamlessly with Pabbly Connect.
To send SMS, follow these steps:
- Go to the Twilio step in Pabbly Connect and click on “Add New Connection”.
- Enter your Twilio Account SID and Auth Token from your Twilio dashboard.
- Compose the SMS message body you want to send.
- Map the recipient’s phone number from your Google Sheets data.
Once you have entered all the necessary information, click on the “Send Test Request” button. This will send a test SMS to verify that everything is set up correctly. If successful, you will receive a confirmation SMS on the mapped phone number.
5. Sending Bulk SMS to Customers
After successfully sending a test SMS, you can now send bulk SMS messages to all the contacts in your Google Sheets. This is where Pabbly Connect shines, allowing you to automate the process for multiple recipients.
To send bulk SMS:
- Return to Google Sheets and click on the Pabbly Connect Webhooks option.
- Select “Send All Data” to forward all customer details to Twilio.
Once you initiate the sending process, Pabbly Connect will automatically send SMS messages to each contact in your sheet, ensuring a seamless communication flow. You can monitor the status of sent messages and confirm delivery through your Twilio dashboard.
In this tutorial, we demonstrated how to use Pabbly Connect to send bulk SMS messages from Google Sheets using Twilio. By following these steps, you can effectively communicate with your customers and promote your business.
Utilizing Pabbly Connect for such integrations not only saves time but also enhances your marketing efforts. Start automating your SMS campaigns today!
