1. Accessing Pabbly Connect for Rakhi Wishes
To send Rakhi wishes, first, you need to access Pabbly Connect. Open a new tab and type in pabbly.com/chatflow. This will take you to the Pabbly Chat Flow landing page.
Click on the “Sign Up for Free” button at the top right corner to start your free trial. After signing up, log in to your account and add your WhatsApp number. This is essential for sending messages through Pabbly Connect.
2. Creating a Broadcast in Pabbly Chat Flow
Once logged into Pabbly Connect, navigate to the broadcast section. Click on the “Add Broadcast” button to start creating your Rakhi wishes campaign.
You will be prompted to select the broadcast type. Choose “Broadcast Campaign” and name your broadcast, such as “Rakhi Wishes”. Then, select your audience by either uploading a CSV file or choosing an existing contact list.
  • Upload a CSV file for contacts.
  • Select an existing contact list.
  • Create a new contact list if needed.
After selecting your audience, you can refine it by excluding specific contacts or those in an active 24-hour conversation window. This feature enhances the efficiency of your broadcast using Pabbly Connect.
3. Setting Up Your Message in Pabbly Chat Flow
In this step, you will define the message type for your Rakhi wishes. Choose between a pre-approved template message or a regular message. For this tutorial, we will use a regular message.
Type your message in the provided field. To emphasize certain text, add stars at the beginning and end of the text you want to bold. This formatting will help your message stand out when sent through Pabbly Connect.
  • Enter the contact name and mobile number for testing.
  • Click on “Send Test Message” to verify.
After sending a test message to yourself, check your WhatsApp to ensure it looks correct. This step ensures that your broadcast will appear as intended when using Pabbly Connect.
4. Scheduling and Sending Your Broadcast with Pabbly Connect
Once your message is verified, you have options for sending it. You can choose to send it instantly or schedule it for later. If scheduling, select the date and time for the broadcast.
Additionally, you can enable the option to automatically retry for failed contacts. This feature is beneficial when sending to large groups, ensuring that all messages reach their recipients. Specify the number of retries and the wait time between them.
After configuring these options, click on the “Add Broadcast” button to finalize your setup. Your Rakhi wishes broadcast is now scheduled successfully using Pabbly Connect.
5. Tracking Broadcast Results in Pabbly Connect
After sending your Rakhi wishes, you can track the performance of your broadcast in Pabbly Connect. Go to the “View Stats” section to see how many messages were sent, delivered, read, and any that failed.
This tracking feature allows you to analyze the effectiveness of your broadcast and make adjustments for future campaigns. You can gain insights into your audience’s engagement and refine your strategies accordingly.
By utilizing Pabbly Connect, you can efficiently manage your messaging campaigns, ensuring timely delivery of your Rakhi wishes to all customers.
In this tutorial, we explored how to send Rakhi wishes using Pabbly Connect and Pabbly Chat Flow. By following the steps outlined, you can efficiently manage your messaging campaigns and engage your audience effectively.
