To send bulk WhatsApp messages, you first need to access Pabbly Connect. This platform enables seamless integration between WhatsApp and your marketing needs. Start by visiting the Pabbly website and signing up for an account.
Once you are logged in, navigate to the Pabbly Connect dashboard. Here, you can create workflows that connect WhatsApp with other applications. This is essential for automating your messaging process and ensuring timely communication with your customers.
2. Creating a Message Template in Pabbly Connect
The next step involves creating a message template, which is crucial for sending bulk messages via WhatsApp. In Pabbly Connect, go to the template section and click on the “Add Template” button. You will need to choose a category, such as “Marketing,” for your Rakhi wishes.
- Select the category as “Marketing”.
- Name your template according to your preference.
- Choose the language for the template.
- Add variables like names or numbers if needed.
After filling in these details, write your message body and include any headers or footers as needed. Once done, submit the template for approval. Remember, Pabbly Connect requires templates to be approved by Meta before use.
3. Sending Bulk Messages via Pabbly Connect
Once your message template is approved, you can send bulk messages. In Pabbly Connect, navigate to the “Add Broadcast” section. Here, you will select the type of broadcast you want to send, such as a campaign type or API campaign.
Next, name your broadcast, for instance, “Rakhi Wishes 2026.” Choose an audience from your existing contact list or upload a CSV file with customer contacts. This step is vital for ensuring your messages reach the right audience.
- Select the audience from your contact list.
- Choose the message type: pre-approved template or a new message.
- Upload any required images for the message.
After setting up your broadcast, it’s essential to test it before sending. This ensures that the message format and content appear correctly on WhatsApp.
4. Scheduling Your Broadcast with Pabbly Connect
After testing your broadcast, you can schedule it using Pabbly Connect. Choose a specific date and time for your messages to be sent, ensuring they reach your customers on the desired occasion, like Rakhi.
Additionally, you can opt for automatic retries for failed contacts, ensuring maximum delivery. This feature helps in maintaining effective communication with your audience.
Once everything is set, add your broadcast to the Pabbly Connect account. You will see it listed as scheduled, ready to be sent at the specified time.
In conclusion, using Pabbly Connect to send bulk WhatsApp messages is an efficient way to engage with your customers. By following these steps, you can easily create, test, and schedule your messages for any occasion, enhancing your marketing efforts.
