1. Access Pabbly Chatflow for Bulk Offers
To send bulk offers, start by accessing Pabbly Chatflow. Open your browser and type in chatflow.com to reach the login page.
Once there, sign up for an account if you haven’t already. After logging in, you will land on the dashboard where you can start setting up your broadcast campaign.
2. Set Up WhatsApp Integration in Pabbly Chatflow
The next step involves integrating your WhatsApp number with Pabbly Chatflow. Navigate to the settings and link your WhatsApp account to ensure smooth communication.
After linking, select the broadcast option from the left menu. This will direct you to the WhatsApp broadcast page where you can create your campaign.
  • Log in to your Pabbly Chatflow account.
  • Navigate to the settings to link your WhatsApp number.
  • Select the broadcast option from the left menu.
Now you are ready to set up your broadcast details in Pabbly Chatflow.
3. Create Your Broadcast Campaign in Pabbly Chatflow
To create a broadcast campaign, select the type of broadcast you want to set up in Pabbly Chatflow. Enter a name for your campaign in the designated field.
You will then need to choose your audience. This can be done by selecting a contact list or uploading a CSV file containing customer details.
  • Select a broadcast type (e.g., promotional).
  • Enter a name for your broadcast campaign.
  • Choose your audience from the contact list or CSV file.
After setting the audience, refine your audience by excluding contacts if necessary. This ensures your messages reach the right customers through Pabbly Chatflow.
4. Compose Your Message and Schedule the Broadcast
With your audience set, it’s time to compose your message in Pabbly Chatflow. You can either send a regular message or use a pre-approved template for WhatsApp.
Once your message is ready, you can schedule it. Choose whether to send it instantly or select a specific date and time for sending.
  • Compose your message in the message field.
  • Choose to send instantly or schedule for later.
  • Select the date and time for the scheduled broadcast.
After scheduling, you can enable options like automatic retries for failed contacts to ensure maximum delivery through Pabbly Chatflow.
5. Finalize Your Broadcast Campaign
Once everything is set, finalize your broadcast campaign in Pabbly Chatflow. Click on the create broadcast button to initiate the campaign.
Your broadcast will be scheduled, and you can check the status by clicking on the view stats button to monitor the progress and delivery rates.
By following these steps, you have successfully set up a bulk offer campaign using Pabbly Chatflow and WhatsApp. This process allows you to engage with your customers effectively.
In this tutorial, we explored how to send bulk offers to customers using Pabbly Chatflow and WhatsApp. By following these steps, you can streamline your marketing efforts and enhance customer engagement.
