To begin integrating Just with WhatsApp, you need to access Pabbly Connect. Start by visiting the Pabbly website and logging into your account. Once logged in, navigate to the Pabbly Connect dashboard to set up your integration.
In the dashboard, you will find options to create new workflows. This is where you will define the actions and triggers necessary for sending bulk messages. Make sure you have your WhatsApp Business account ready, as it will be essential for this integration.
2. Setting Up Pabbly Chat Flow for WhatsApp
After accessing Pabbly Connect, the next step is to set up Pabbly Chat Flow. This tool is crucial for managing your WhatsApp communications. Navigate to the Chat Flow section and ensure your WhatsApp number is added correctly.
- Log in to Pabbly Chat Flow.
- Add your WhatsApp number in the settings.
- Confirm your number to avoid any messaging issues.
Once your WhatsApp number is set up, you can proceed to create a broadcast list. This list will include all the clients you wish to send membership renewal reminders to. Ensure that your contacts are organized for a smooth messaging experience.
3. Creating Broadcasts in Pabbly Connect
In this section, you will use Pabbly Connect to create a broadcast for sending messages to multiple clients. Click on the broadcast section and select ‘Add Broadcast’. Choose the type as ‘Broadcast Campaign’ and name it appropriately, such as “Membership Reminder”.
Next, select the contact list you previously created. This list should contain the clients who need to receive the reminders. You can also exclude certain contacts if necessary, ensuring that your messages reach the right audience.
4. Sending Messages Using Pabbly Connect
Now that your broadcast is set up, it’s time to send the messages through Pabbly Connect. You have the option to either send the messages instantly or schedule them for a later date. If you choose to schedule, select the date and time for sending the reminders.
- Choose ‘Send Instantly’ for immediate delivery.
- Select ‘Schedule for Later’ and pick your desired date and time.
- Enable automatic retries for failed messages, if necessary.
After configuring these options, click on ‘Add’ to finalize your broadcast. You can then monitor the status of your sent messages in the sent section of Pabbly Connect to see how many were delivered, read, or failed.
5. Monitoring Your Broadcasts in Pabbly Connect
Monitoring the effectiveness of your broadcasts is crucial. Within Pabbly Connect, you can check the statistics of your messages. This includes how many messages were sent, delivered, ignored, or failed. This data will help you refine future broadcasts.
To view these statistics, navigate to the sent section of your broadcasts. Here, you will find detailed insights about each message, allowing you to assess the performance and adjust your strategies accordingly. This feature is vital for ensuring your communications are effective and reaching your intended audience.
In conclusion, integrating Just and WhatsApp using Pabbly Connect allows you to automate your membership renewal reminders efficiently. By setting up broadcasts and monitoring their performance, you can ensure timely communication with your clients.
