1. Access Pabbly Connect to Start Automation
To automate daily AI image sharing on Discord, you first need to access Pabbly Connect. If you’re a new user, open your browser and go to pabbl.com/connect. Here, you can sign up for free and get 100 tasks every month to explore the features.
Once you’re logged in, you’ll be directed to the workflow builder of Pabbly Connect. This is where you will set up the automation process. You can create your workflows by adding triggers and actions, which are fundamental to how Pabbly Connect operates.
2. Setting Up the Trigger with Pabbly Connect
The first step in your automation is to set up a trigger in Pabbly Connect. Click on the “Add Trigger” button and search for “Schedule by Pabbly”. This feature allows you to schedule your workflows.
  • Select the event as “Schedule Workflow”.
  • Choose how often you want to run your workflow; in this case, select “Every Day”.
  • Set the specific time for the workflow, for example, 1 PM.
After configuring these settings, click “Save”. Your workflow is now scheduled to run daily at the specified time using Pabbly Connect.
3. Generating AI Images Using Gemini with Pabbly Connect
Next, you will need to generate the AI images that you want to share on Discord. Click on “Add New Action Step” and search for “Gemini” (Google AI Studio). Select this application to proceed.
For the event, choose “Generate Image” and connect it to your existing account or create a new connection using the API key from Google AI Studio. This key can be obtained by navigating to the “Get API Key” section in your Google AI Studio account.
  • Select the model, preferably “Nano Banana 2”.
  • Set the method to “Generate Content”.
  • Enter a prompt for the image you want to generate.
Click “Save” and send a test request to check if the AI image is generated successfully. This image will be the one shared on your Discord channel, facilitated by Pabbly Connect.
4. Sharing Generated Images on Discord Using Pabbly Connect
Once the image is generated, the next step is to share it on your Discord channel. Click on “Add New Action Step” again and search for “Discord”. Select the Discord application and choose the event for sending a channel message.
To set this up, you will need to create a webhook in your Discord server. Access your server settings, navigate to “Integrations”, and click on “Webhooks”. Create a new webhook and copy the URL provided.
  • Paste the copied webhook URL into Pabbly Connect.
  • Map the message field to include the image URL generated by Gemini.
  • Click “Save” and send a test request to ensure the image is shared.
After successfully sending the test message, your automation is complete, and Pabbly Connect will handle the daily sharing of AI images on your Discord channel.
5. Conclusion: Automate Your Discord Image Sharing with Pabbly Connect
In conclusion, using Pabbly Connect to automate the sharing of AI-generated images on Discord is a straightforward process. By following the steps outlined above, you can set up a daily automation that runs without manual intervention.
With Pabbly Connect, you can easily integrate various applications to enhance your workflow and productivity. Try it out today and simplify your daily tasks!
