To begin automating the posting of AI-generated images on Discord, you need to access Pabbly Connect. Start by visiting pabbl.com/connect in your browser.
If you are a new user, click on the “Sign up for free” option in the top right corner. This grants you 100 free tasks every month to explore Pabbly Connect and its features.
2. Setting Up Your Workflow in Pabbly Connect
After signing up, you will access the workflow builder in Pabbly Connect. This is where you will create your automation process.
  • Click on the “Add Trigger” button.
  • Select “Scheduled by Pabbly” as your trigger application.
  • Choose “Schedule Workflow” as the event.
  • Set the frequency to “Every Day” and the time to “12 p.m.”.
Click on “Save” to finalize the trigger settings. Now, your workflow will run every day at the specified time.
3. Generating AI Images with Google AI Studio
Next, you will configure Pabbly Connect to generate images using Google AI Studio. Click on “Add New Action Step” and search for “Gemini”.
Select “Generate and Edit Image” as the event. If you need to create a new connection, you will require an API key from Google AI Studio. Follow these steps to obtain it:
  • Navigate to Google AI Studio and find the “Get API Key” section.
  • Click on the “Create API Key” button and name your key.
  • Copy the generated API key and paste it into Pabbly Connect.
After connecting, set the model to “Nano Banana” and enter your prompt. Click on “Save and Send Test Request” to generate the image.
4. Posting Generated Images on Discord
Once the image is generated, it’s time to post it on Discord. In Pabbly Connect, click on “Add New Action Step” and select “Discord”.
Choose the event as “Send Channel Message”. If you haven’t created a connection before, log in to your Discord account and authorize Pabbly Connect to access your server.
  • Go to the Discord channel settings and create a new webhook.
  • Copy the webhook URL and paste it into Pabbly Connect.
  • Extract the webhook token from the URL and enter it in the respective field.
Map the image URL generated earlier as the message text and click on “Send Test Request” to confirm the setup. You should see the image posted successfully in your Discord channel.
5. Conclusion
By following this tutorial, you have successfully automated the posting of AI-generated images on Discord using Pabbly Connect. This powerful tool allows for seamless integration between various applications, enhancing your workflow.
Explore more automation possibilities with Pabbly Connect to streamline your business processes and save time.
