1. Sending Rocky Wishes via WhatsApp with PABY
Sending Rocky wishes to your customers on WhatsApp is easy using PABY Chartflow. This approach helps maintain customer engagement and fosters loyalty. By sending bulk messages, you can reach thousands of customers effortlessly.
To start, ensure you have your WhatsApp number linked to your PABY Chartflow account. This integration allows you to automate your messaging, making it a seamless process. Remember, personalization is key to making your messages resonate with your audience.
2. Setting Up Your PABY Chartflow Account
To set up your PABY Chartflow account, visit pabyt.com/chartflow. If you’re a new user, sign up for free to receive 100 credits. This will allow you to test the features immediately.
  • Visit pabyt.com/chartflow
  • Sign up for a free account
  • Receive 100 free credits
After logging in, navigate to the contact section to create a list of customer contacts. This is essential for sending bulk messages later. Ensure that your contact list is accurate and up-to-date.
3. Creating a Template for WhatsApp Messages
To send bulk WhatsApp messages, you need to create a message template in PABY Chartflow. Go to the “Add Template” option and fill in the required fields.
  • Select the template category as “Marketing”
  • Name the template according to your requirement
  • Choose the language for your message
  • Select “Image” as the template type
After entering the message body and footer, submit the template. It will go into a pending status for approval from Meta. Once approved, you can use it to send messages to your contacts.
4. Sending Bulk Messages Using PABY Chartflow
After your template is approved, you can send it to multiple contacts. Click on the “Add Broadcast” button in your PABY Chartflow account.
Select the broadcast type as “Broadcast Campaign” and name it according to your needs. Choose the audience by selecting the contact list you created or upload a CSV file directly.
In the broadcast setup, you can also exclude specific contacts if needed. Select the message type and choose your approved template. This ensures that your message is sent in the desired format.
5. Scheduling Your WhatsApp Broadcast
Once everything is set up, you can schedule your broadcast for a specific date and time. For instance, if you want to send Rocky wishes on Raa Bandhan, set the date to August 28, 2026, at 12 PM.
Before finalizing, test the broadcast by sending a test message to your own WhatsApp number. This allows you to see how the message will appear to your customers.
After confirming that everything looks good, finalize the schedule. Your message will then be sent automatically at the specified time, ensuring your customers receive their Rocky wishes right on time.
Integrating WhatsApp with PABY allows you to send bulk messages effectively. By following these steps, you can enhance customer engagement and ensure timely communication. Utilize PABY Chartflow to automate your WhatsApp interactions seamlessly, creating a positive experience for your customers.
