To start automating your daily messages, access Pabbly Connect by visiting pabbl.com/connect. If you’re a new user, click on the “Sign Up for Free” option in the top right corner. This allows you to explore Pabbly Connect with 100 free tasks every month.
Existing users can directly open their workflow builder. After signing up, you can create automation to schedule daily messages without manual effort. This is particularly useful for communities on platforms like Discord.
Once you’re in the workflow builder of Pabbly Connect, click on the “Add Trigger” button to start. You will need to search for the “Schedule by Pabbly” application. Select the event as “Schedule Workflow” and set it to run daily at 1 p.m.
  • Click on “Add Trigger”.
  • Search for “Schedule by Pabbly”.
  • Select the event as “Schedule Workflow”.
  • Set the time to 1 p.m.
After saving the trigger, you can now proceed to add an action step. This will be where you generate the message to send daily. With Pabbly Connect, you can automate this entire process seamlessly.
3. Generating Daily Messages Using Google AI
Next, add a new action step by searching for the Google AI application, specifically Google Gemini. Select the event as “Generate Content”. If you have an existing connection, select it; otherwise, create a new connection using your API key.
To obtain the API key, go to Google AI Studio, navigate to the “Get API Key” section, and create a new key. Copy this key and paste it into your Pabbly Connect workflow. This step is vital for enabling the integration between Google AI and Pabbly Connect.
  • Go to Google AI Studio to create your API key.
  • Copy the API key and paste it in Pabbly Connect.
  • Input your prompt for the message generation.
After saving this action, you will be able to generate unique daily messages for your Discord community using Pabbly Connect and Google AI.
4. Sending Messages to Discord via Pabbly Connect
After generating the message, the next step is to send it to Discord. Add another action step in Pabbly Connect and search for the Discord application. Choose the event “Send Channel Message” and connect it to your Discord account.
To set this up, you will need a webhook URL from Discord. Go to your Discord server settings, navigate to “Integrations”, and create a new webhook. Copy the webhook URL and paste it into your Pabbly Connect workflow.
  • Create a new webhook in Discord.
  • Copy the webhook URL.
  • Paste the webhook URL into Pabbly Connect.
Map the message generated from Google AI to the message field in your Discord action. This ensures that each day, a unique message is sent to your community automatically.
5. Testing Your Pabbly Connect Workflow
Once everything is set up, it’s time to test your workflow in Pabbly Connect. Click on “Save and Send Test Request” to check if the message is being sent to your Discord channel. You should see a positive response indicating that the message was successfully sent.
If the test is successful, your automation is now ready to run daily without any manual intervention. You can also customize the prompt for the messages according to your community’s needs.
Using Pabbly Connect, you can easily integrate various applications to enhance your workflow, making it a powerful tool for automating tasks like sending daily messages.
In this tutorial, we demonstrated how to automate daily messages using Pabbly Connect, integrating Google AI and Discord. This process allows you to streamline communication without manual effort, enhancing engagement within your community.
