To start integrating Pabbly with Catch Webhook, the first step is to access Pabbly Connect. You can do this by visiting pabbly.com and signing in to your account.
Once you are on the Pabbly homepage, click on “Sign In” at the top right corner. If you don’t have an account, you can choose “Free Sign Up” to create one. After logging in, you will be directed to the Pabbly Connect dashboard where you can manage your workflows.
Next, you will create a new workflow in Pabbly Connect. Click on the “Create from Scratch” option to start a new automation process.
Give your workflow a name, such as “Save Website Leads to Airtable Automatically”. You will also need to select a folder for your workflow. Choose the folder named “Forms Automation” and click on “Create”.
- Click on “Create from Scratch”.
- Name your workflow.
- Select the appropriate folder.
Your workflow will now be created, and you will see the trigger step where you can define what starts this automation.
The next step is to set up the trigger in Pabbly Connect. This trigger will activate the workflow when a form is submitted on your website.
Select “Catch Webhook” as the trigger application. Click on “Connect” to generate a unique webhook URL. This URL will be used to connect your website’s form to Pabbly Connect.
- Choose “Catch Webhook” as the trigger application.
- Click on “Connect” to generate a webhook URL.
- Copy the webhook URL for later use.
After copying the webhook URL, you will need to paste it into your website’s form code to establish the connection.
4. Testing the Connection with a Form Submission
Once you have pasted the webhook URL into your form code, it’s time to test the connection. Go back to your Pabbly Connect workflow and refresh the page.
Fill out your form with sample data, such as your name, email, and phone number, then submit the form. After submission, check Pabbly Connect to see if the webhook response has been captured. This will confirm that the integration is working correctly.
- Refresh the Pabbly Connect page.
- Fill out the form with sample data.
- Submit the form and check for the webhook response.
Once you see the details captured in Pabbly Connect, you can move on to the next step of adding the data to your Airtable database.
5. Adding Data to Airtable from Pabbly Connect
The final step is to add the captured data to your Airtable database using Pabbly Connect. For this, select Airtable as the action application and choose “Create Record” as the action event.
Connect your Airtable account by providing the necessary access permissions. Once connected, select the base you want to use, such as “Website Leads”, and map the fields accordingly to ensure the data flows correctly from your form submissions.
After mapping the fields, send the request to Airtable. Refresh your Airtable database to verify that the new record has been added successfully.
By following these steps, you have successfully integrated Pabbly with Catch Webhook using Pabbly Connect. This automation allows for seamless data management and enhances your workflow efficiency.
This tutorial demonstrated how to integrate Pabbly with Catch Webhook using Pabbly Connect. By following these steps, you can automate your data management processes efficiently.
