1. Setting Up Pabbly Connect for Instagram Stories
To create automated Instagram stories, start by accessing Pabbly Connect. This platform allows seamless integration between various applications, including Google Sheets and Instagram.
Visit the Pabbly Connect website and sign up for a free account. You will receive 100 free tasks every month, which is perfect for setting up your Instagram story automation.
Now, let’s integrate Google Sheets with Pabbly Connect. This step captures your Instagram story ideas automatically. First, create a new Google Sheet and enter your story idea in the first column.
  • Open your Google Sheet and navigate to Extensions.
  • Click on Add-ons, then Get Add-ons.
  • Search for Pabbly Connect Webhooks and install it.
After installation, refresh your Google Sheet and set up the webhook URL provided by Pabbly Connect. This URL will capture your story ideas as they are entered into the spreadsheet.
3. Generating Instagram Story Images Using AI
Next, we will generate Instagram story images using OpenAI integrated through Pabbly Connect. This process will create visually appealing content based on the ideas you input.
In Pabbly Connect, select OpenAI as your application and set it to generate images. You will need to provide your OpenAI API key to connect. This key can be generated from your OpenAI account dashboard.
  • Choose the image generation model you want to use.
  • Enter your prompt to guide the AI in creating the story image.
  • Map the data from the Google Sheet to dynamically update the image based on your story idea.
Once the image is generated, you will receive a file URL that can be used in the next steps of your workflow.
4. Uploading the Story to Instagram
Now that you have your image, it’s time to upload it to Instagram using Pabbly Connect. This requires connecting your Instagram for Business account through Facebook.
In Pabbly Connect, select Instagram for Business as your application and choose the “Create Story” action. Make sure your Instagram account is linked with your Facebook account to facilitate this connection.
  • Map the image URL you generated in the previous step.
  • Click on “Save and Send Test Request” to upload the story.
  • Receive a story container ID in the response to confirm the upload.
This step ensures your story is published on your Instagram profile, ready for your audience to view.
5. Updating Google Sheets with Story Status
Finally, we want to update our Google Sheet to reflect the status of the Instagram story using Pabbly Connect. This helps keep track of which stories have been published.
Select Google Sheets again in Pabbly Connect and choose the action to update cell values. Connect your Google account and select the spreadsheet where you want to update the status.
  • Specify the column and row index for the status update.
  • Enter “Created” as the value to indicate that the story has been published.
  • Click on “Save and Send Test Request” to finalize the update.
This step completes the automation, allowing you to see which stories have been successfully posted on your Instagram profile directly from your Google Sheet.
Using Pabbly Connect, you can create Instagram stories automatically, saving time and enhancing your content creation process. This integration with Google Sheets and OpenAI simplifies your workflow for effective storytelling.
