To begin integrating Let and Apollo, first access Pabbly Connect. If you’re a new user, open a browser and navigate to pabli.com/connect. Sign up for a free trial to explore the integration capabilities.
Once logged in, you’ll be taken to the workflow builder. This interface is where you can set up automations between different applications. Make sure to familiarize yourself with the layout as you will be using it extensively.
2. Setting Up the Workflow in Pabbly Connect
In the workflow builder of Pabbly Connect, you need to establish a trigger and an action. The trigger will start the automation process, while the action will determine what happens next. Click on the “Add Trigger” button to get started.
  • Select “Typeform” as the trigger application.
  • Choose “New Entry” as the trigger event.
  • Click on “Connect” to link your Typeform account.
Make sure your Typeform account is logged in to allow Pabbly Connect to access it. Accept all permissions requested to ensure smooth operation.
3. Capturing Data from Typeform
Once the trigger is set, you need to capture the data from Typeform. To do this, fill out the form you selected in the previous step. For example, enter a name like “Jane”, an email, and other necessary details.
After submitting the form, return to Pabbly Connect. Click on “Save and Send Test Request”. This action will allow you to see if the data has been captured correctly. If successful, you should see the details reflected in the workflow.
4. Connecting Apollo to Pabbly Connect
Now that you have captured the data, it’s time to set up the action step to connect Apollo. Click on “Add New Action Step” and search for “Apollo”. Select it as the action application.
  • Choose “Create Contact” as the action event.
  • Click on “Connect” to link your Apollo account.
  • Enter your Apollo API key when prompted.
To get the API key, go to your Apollo account, navigate to “Admin Settings”, then “Integrations”, and create a new API key. Copy this key and paste it into Pabbly Connect to establish the connection.
5. Mapping Data to Apollo and Testing the Integration
After connecting Apollo, you will need to map the data captured from Typeform to the fields in Apollo. This step is crucial for ensuring that the correct information is sent to Apollo.
For mapping, select the fields from the Typeform data and match them with the corresponding fields in Apollo. Once you finish mapping, click on “Save and Send Test Request” to test the integration. If successful, you will receive a confirmation that a new contact has been created in Apollo.
Now, you can check your Apollo account to see the newly created contact. This automation means that every time a new form is filled out, the contact will be created in Apollo without any manual effort, thanks to Pabbly Connect.
In this tutorial, we explored how to automate the integration of Let and Apollo using Pabbly Connect. By following these steps, you can streamline your workflow and ensure that every new lead is captured efficiently. Try it out today for a seamless experience!
