1. Access Pabbly Connect for WhatsApp Marketing
To execute WhatsApp marketing campaigns without manual effort, start by accessing Pabbly Connect. Navigate to pabbly.com/chatflow in your browser to reach the Pabbly Chat Flow homepage.
If you’re a new user, click on the “Sign Up Free” button to create an account. Existing users can simply log in. Once logged in, you can explore the various features of Pabbly Connect that facilitate WhatsApp integration.
2. Create a Broadcast using Pabbly Chat Flow
In this section, we will create a broadcast in Pabbly Chat Flow. Locate the “Add Broadcast” button on your dashboard. Click on it to initiate the process.
Choose the type of broadcast campaign you want to create. For example, if you want to send a promotional message, select the appropriate template. Here’s how to proceed:
  • Select the type of broadcast campaign.
  • Name your campaign (e.g., “New Quick Discounts”).
  • Choose your audience from existing contact lists or upload a CSV file.
Once you’ve set up the initial details, you can customize your message and add any images or variables needed for personalization. This customization is crucial for enhancing engagement.
3. Import Contacts into Pabbly Connect
To effectively run your campaign, you need to import contacts. You can do this in Pabbly Connect by uploading a CSV file or selecting existing contacts. If you have data in Google Sheets, download it as a CSV first.
After importing, you can refine your audience further using features like:
  • Excluding contacts you do not wish to message.
  • Choosing specific lists for targeted messaging.
  • Utilizing audience optimization options.
Once your contacts are ready, you can proceed to the next step of your WhatsApp marketing campaign.
4. Schedule Your Broadcast with Pabbly Chat Flow
Scheduling your broadcast is a key feature of Pabbly Chat Flow. You can choose to send your messages immediately or at a later date. When scheduling, ensure you select a future date and time to avoid sending messages immediately.
Here’s how to schedule your broadcast:
  • Choose the “Schedule” option.
  • Set the desired date and time.
  • Enable automatic retries for failed messages.
After scheduling, you can view the statistics of your broadcast, including sent, delivered, and read messages, ensuring that you can track the effectiveness of your campaign.
5. Test Your Broadcast with Pabbly Connect
Before launching your broadcast, it’s essential to test it. Use Pabbly Connect to send a test message to your own WhatsApp number. This ensures that everything appears as intended.
To test your broadcast:
  • Select the “Test Broadcast” option.
  • Send the test message to your WhatsApp.
  • Check for successful delivery and correct formatting.
Once you confirm the test is successful, you can confidently launch your campaign to your entire contact list.
This tutorial demonstrated how to execute WhatsApp marketing campaigns efficiently using Pabbly Connect. By leveraging features like broadcast scheduling and audience optimization, you can enhance your marketing efforts significantly.
