To create a WhatsApp AI assistant, you first need to access Pabbly Connect. This platform acts as the central hub for integrating various applications, including WhatsApp and your AI assistant.
To get started, visit the Pabbly Connect website and log in to your account. If you’re a new user, you can sign up for free to explore the platform’s features. Once logged in, navigate to the dashboard where you can create a new workflow.
2. Creating Your WhatsApp AI Assistant with Pabbly Connect
After accessing Pabbly Connect, you can begin setting up your WhatsApp AI assistant. Start by selecting the “Create Workflow” option. This will allow you to choose the applications you want to integrate.
  • Choose WhatsApp as your trigger application.
  • Select the trigger event, such as receiving a message.
  • Connect your WhatsApp account to Pabbly Connect.
By following these steps, you will set up the initial connection between WhatsApp and Pabbly Connect. This allows your AI assistant to respond to incoming messages automatically.
3. Configuring Your AI Assistant in Pabbly Connect
Now that you’ve set up the WhatsApp integration, it’s time to configure your AI assistant. Go to the AI assistant page in Pabbly Chatflow, where you can input various settings.
Here are the key configurations you need to make:
  • Select the AI model, such as OpenAI’s GPT.
  • Set the temperature for creativity in responses.
  • Enter your OpenAI API key to enable the connection.
These settings will help your AI assistant generate appropriate responses based on the messages received through WhatsApp, leveraging the capabilities of Pabbly Connect to facilitate the integration.
4. Building a Knowledge Base for Your AI Assistant
To enhance your AI assistant’s capabilities, you need to create a knowledge base. This document serves as the brain of your assistant, providing it with the necessary information to respond effectively.
Upload your knowledge base in either TXT or PDF format through Pabbly Connect. Ensure it contains essential details about your business, such as:
  • Business overview and services offered.
  • Common queries and FAQs.
  • Documentation requirements for your industry.
By providing comprehensive information, your AI assistant can deliver accurate and timely responses to customer inquiries via WhatsApp, all thanks to the seamless integration powered by Pabbly Connect.
5. Enabling Auto Replies for Your Contacts
Once your AI assistant is configured and the knowledge base is uploaded, the final step is to enable auto replies for your WhatsApp contacts. This ensures that your customers receive immediate responses to their queries.
In Pabbly Connect, navigate to the inbox settings, where you can enable auto replies. You can choose to activate this feature for all contacts or specific lists. Additionally, select the AI assistant you created earlier to handle these interactions.
By completing these steps, your WhatsApp AI assistant is now fully operational. It will respond to customer inquiries instantly, enhancing customer satisfaction and improving your business efficiency with the help of Pabbly Connect.
By following this guide, you have successfully created a WhatsApp AI assistant using Pabbly Connect. This integration allows you to respond to customer inquiries instantly, improving your business’s efficiency and customer satisfaction.
