To start integrating your dental clinic’s operations, access Pabbly Connect by visiting pabbly.com/chatbot. This platform is essential for automating your appointment bookings through WhatsApp.
If you are new to Pabbly Connect, you can sign up for a free account which provides you with 100 credits every month. Existing users can simply sign in to their accounts to begin.
2. Creating Your AI Assistant with Pabbly Connect
Once logged into Pabbly Connect, navigate to the Pabbly Chatbot dashboard. Here, you can create an AI assistant that will handle patient inquiries and appointment bookings automatically.
- Click on the “Add AI Assistant” button.
- Enter a descriptive name for your assistant, e.g., “Dental Clinic Receptionist”.
- Select the instruction type as “AI Agent”.
This setup allows your AI assistant to respond to patient inquiries effectively, ensuring no call goes unanswered.
In this section, you will configure various settings for your AI assistant using Pabbly Connect. This includes setting the temperature for responses and selecting the model provider.
Here’s how to configure:
- Set the temperature to 0.5 for balanced responses.
- Choose OpenAI as the model provider and select GPT-4 Mini.
- Enter your OpenAI API key to connect your assistant.
These configurations will enhance your assistant’s ability to engage with patients effectively, ensuring they receive accurate and timely responses.
4. Uploading Knowledge Base for Your AI Assistant
To make your AI assistant effective, you need to upload a knowledge base file using Pabbly Connect. This file should contain all relevant information about your dental clinic.
Follow these steps to upload your knowledge base:
- Create a knowledge base file in PDF or .txt format.
- Ensure the file size is less than 90 MB and upload it in the Pabbly Chatbot interface.
- Click on “Add New File” and select your knowledge base to upload.
This knowledge base will empower your AI assistant to provide accurate information and responses to patient inquiries, streamlining the appointment booking process.
5. Finalizing Your AI Assistant Setup
After configuring your AI assistant, the final step is to complete its setup using Pabbly Connect. This includes designing the assistant interface and activating it.
To finalize your assistant:
- Customize the assistant’s appearance by entering a header and footer message.
- Enable the AI auto-reply settings in the inbox settings.
- Save your settings and activate the assistant.
This ensures that your AI receptionist is fully operational and ready to assist patients with their inquiries and appointment bookings, enhancing your clinic’s efficiency.
In this tutorial, we explored how to use Pabbly Connect to create an AI assistant for your dental clinic. By automating appointment bookings and inquiries, you can enhance patient experience and reduce missed calls.
