1. Setting Up Integration Between WooCommerce and Pabyt Chatflow
To integrate Over with URL using Make, we first need to connect WooCommerce with Pabyt Chatflow. This integration will help automate WhatsApp messages whenever a customer abandons their cart. Begin by signing into your Pabyt account and accessing the Pabyt Connect dashboard.
Once in the dashboard, create a new workflow by clicking on the ‘Create Workflow’ button. Name this workflow something like ‘Recover WooCommerce Sales with Automated WhatsApp Reminder’. Select a folder for your workflow, and click ‘Create’. This sets up the foundation for our automation.
2. Configuring the Trigger for Cart Abandonment
In this section, we will configure the trigger for cart abandonment in WooCommerce. The trigger is essential as it initiates the workflow whenever an item is left in the cart. In the trigger application, select WooCommerce and choose the event ‘New Cart Abandonment’. Click ‘Connect’ to link your WooCommerce store.
  • Open WooCommerce settings in your WordPress dashboard.
  • Navigate to the Cart Abandonment settings and enable tracking.
  • Enter the provided webhook URL to connect WooCommerce with Pabyt Connect.
After setting up the webhook, ensure you send a trigger sample from WooCommerce to verify the connection. This will help confirm that the integration is working correctly.
3. Automating WhatsApp Messages with Pabyt Chatflow
Now that we have configured the trigger, the next step is to automate the WhatsApp messages using Pabyt Chatflow. In the action application, search for Pabyt Chatflow and select ‘Send Text Message’. This action will send a personalized message to customers when they abandon their carts.
To connect Pabyt Chatflow, you will need to enter your API token. Navigate to the settings in Pabyt Chatflow, find the API section, and copy the token. Paste this token back into Pabyt Connect to establish the connection.
  • Map the phone number from WooCommerce to ensure messages are sent to the correct customer.
  • Create a personalized message that includes the customer’s first name and the checkout URL.
  • Test the message by sending a sample to verify that everything is set up correctly.
Once you have mapped the necessary fields, save and send a test request to check the automation. If successful, you will receive a WhatsApp message confirming the integration.
4. Finalizing the Workflow and Testing
After setting up the messaging automation, it’s time to finalize the workflow. Go back to your Pabyt Connect dashboard and ensure all steps are correctly configured. Click on ‘Recapture Webhook Response’ to test the complete workflow.
Perform a test by adding items to your WooCommerce cart and abandoning it. This will help you see if the WhatsApp message is sent as expected. Ensure that the message contains the necessary details, such as the product name and checkout URL.
By following these steps, you will have created a fully functional automation that sends WhatsApp messages for abandoned carts. This can significantly improve your sales recovery efforts.
Integrating Over with URL using Make allows you to automate WhatsApp messages for abandoned carts in WooCommerce. This setup enhances customer engagement and can lead to increased sales recovery. Implement this automation to streamline your e-commerce operations effectively.
