1. Accessing Pabbly Connect for Your E-commerce Needs
To start recovering abandoned carts, you first need to access Pabbly Connect. Simply visit the Pabbly Connect website and log into your account. If you don’t have an account, sign up for free to get started with 100 free tasks.
Once logged in, you will land on the Pabbly Connect dashboard. Here, you can create a new workflow by clicking on the “Create Workflow” button. This is where the automation process begins, enabling you to integrate various applications seamlessly.
2. Setting Up Your Workflow in Pabbly Connect
In this step, you will set up the workflow to automatically notify customers via WhatsApp when they abandon their carts. First, click on the “Create Workflow” button and select the AI feature to help build your workflow.
- Choose the trigger event: “When a customer abandons their cart in WooCommerce”.
- Select the action event: “Send a WhatsApp message template”.
- Approve and create the workflow.
After setting up the workflow, you will see the entire setup created automatically. This simplifies the process and ensures that you have all necessary integrations in place.
3. Integrating WooCommerce with Pabbly Connect
To connect WooCommerce with Pabbly Connect, you need to copy the provided webhook URL. Log into your WordPress admin panel and install the WooCommerce Abandoned Cart Recovery plugin.
- Search for and install the WooCommerce Abandoned Cart Recovery plugin.
- Activate the plugin and enable tracking in the settings.
- Paste the webhook URL from Pabbly Connect into the plugin settings.
Once you have set everything up, test the connection by refreshing the workflow in Pabbly Connect. This ensures that the data is being captured correctly when a cart is abandoned.
4. Sending WhatsApp Notifications Using Pabbly Connect
Now that WooCommerce is connected to Pabbly Connect, it’s time to set up the WhatsApp notification. Use Pabbly Chatflow to send a template message to customers who abandon their carts.
To do this, you will need to create a WhatsApp template message in Pabbly Chatflow and connect it to your Pabbly Connect workflow. Here’s how:
- Select the “Send Template Message” action in your Pabbly Connect workflow.
- Map the phone number and name fields from the previous step.
- Test the setup to ensure messages are sent correctly.
This integration allows you to engage customers effectively, encouraging them to complete their purchases with personalized messages.
5. Finalizing Your Automation with Pabbly Connect
After setting up the WhatsApp notification, you can finalize your automation in Pabbly Connect. Ensure that all data fields are mapped correctly, and perform a final test to confirm that everything works as expected.
Once you have verified the setup, your automation is complete. Customers will now receive timely reminders via WhatsApp whenever they abandon their carts, significantly improving your chances of recovering lost sales.
In conclusion, using Pabbly Connect to recover abandoned carts can streamline your e-commerce operations. By integrating WooCommerce and WhatsApp, you enhance customer engagement and improve conversion rates effectively.
