1. Accessing Pabbly Connect for Real Estate Meta Ads
To start using Pabbly Connect for your real estate ads, visit pabbly.com/connect. This platform allows you to integrate various applications seamlessly.
Once on the site, you can register for a free account, granting you 100 free tasks each month. This is ideal for setting up your real estate lead generation system without incurring costs.
2. Setting Up Facebook Lead Ads with Pabbly Connect
After logging into Pabbly Connect, the first step is to create a connection with Facebook Lead Ads. This will allow you to capture leads directly from your Meta ads.
Follow these steps to set up the connection:
- Go to “Add New Connection” and select “Connect with Facebook Lead Ads”.
- Log into your Facebook account when prompted.
- Select your business page, in this case, “Prime Properties”.
Once the connection is established, you can choose the lead form you want to use for capturing potential clients. Make sure to save your settings and test the connection.
3. Capturing Leads in Google Sheets via Pabbly Connect
Next, you will set up Pabbly Connect to save the captured leads into Google Sheets. This ensures that all your leads are organized and easily accessible.
Here’s how to do it:
- Add a new step in Pabbly Connect and select “Add Row” in Google Sheets.
- Connect your Google account.
- Choose the spreadsheet where you want to store the leads.
Make sure to map the fields correctly—name, email, phone number, and city—so that each lead is recorded accurately in your spreadsheet.
4. Sending WhatsApp Messages Using Pabbly Chatflow
To enhance your engagement, you can automate WhatsApp messages to your leads using Pabbly Chatflow. This sends a promotional message immediately after a lead is captured.
Follow these steps to set up WhatsApp messaging:
- Choose “Send Template Message” from Pabbly Chatflow.
- Connect your Chatflow account using the API key found in your Chatflow settings.
- Input the lead’s phone number and the message template.
Once set up, every new lead will receive a WhatsApp message, enhancing your chances of conversion right away.
5. Conclusion: Streamlining Real Estate Leads with Pabbly Connect
Using Pabbly Connect to automate your real estate lead generation through Meta ads can significantly enhance your efficiency. By integrating Google Sheets and WhatsApp, you ensure that every lead is captured and followed up promptly.
This streamlined process not only saves time but also improves your chances of converting leads into clients. Implement these strategies today to maximize your real estate marketing efforts!
