To start automating your WhatsApp conversations, you need to access Pabbly Connect. Begin by visiting the Pabbly website and signing in or signing up if you are a new user. This is crucial for setting up your WhatsApp chatbot.
Once logged in, navigate to the Pabbly Connect dashboard. From here, you can add your WhatsApp number by clicking on the ‘Add WhatsApp Number’ button. This step is essential to connect your WhatsApp account with Pabbly Connect.
2. Creating Your WhatsApp Chatbot with Pabbly Connect
After setting up your WhatsApp number, the next step is to create your chatbot. You will do this by accessing the AI Assistant feature within Pabbly Connect. Click on ‘Add AI Assistant’ to begin the process of chatbot creation.
  • Name your AI Assistant (e.g., Real Estate Bot).
  • Select the AI instruction type from the dropdown menu.
  • Configure AI settings such as temperature and model.
Once these steps are completed, click on the ‘Add AI Assistant’ button to finalize the creation of your chatbot. This is a critical step in leveraging Pabbly Connect for WhatsApp automation.
3. Configuring Your AI Assistant in Pabbly Connect
With your AI Assistant created, it’s time to configure it. You will need to set up specific instructions for the assistant to respond to user queries effectively. This includes setting the temperature for creativity and adding API keys.
To do this, navigate to the AI Assistant settings. Here, you can add fallback messages, stop keywords, and retry attempts for queries that cannot be resolved. Ensure that your settings are tailored to provide the best user experience on WhatsApp.
  • Add fallback messages for unrecognized queries.
  • Set stop keywords to halt responses when necessary.
  • Specify retry attempts for unresolved queries.
After configuring these settings, save your changes to ensure that your AI Assistant is ready to interact with users effectively through Pabbly Connect.
4. Enabling Your Assistant for WhatsApp Chats
Now that your AI Assistant is configured, the next step is enabling it for your WhatsApp chats. You can do this by accessing the inbox settings in Pabbly Connect. Select the specific chat where you want to enable the assistant.
Once in the chat settings, toggle the AI Assistant option to ‘On’ and save your changes. This will ensure that your assistant is actively responding to incoming messages on WhatsApp. You can also enable it for multiple chats by selecting a contact list.
5. Finalizing Your WhatsApp Integration with Pabbly Connect
After enabling your AI Assistant for chats, the final step is to embed it within your website. Navigate to the ‘Embed’ section in Pabbly Connect to obtain the code snippet that you will place on your website.
Once embedded, users will be redirected to WhatsApp when they click on the assistant option on your site. This completes the integration process, allowing your WhatsApp chatbot to operate seamlessly.
By following these steps, you have successfully set up a WhatsApp chatbot using Pabbly Connect. This automation can significantly enhance customer interactions and streamline responses.
In conclusion, using Pabbly Connect to automate WhatsApp conversations can greatly benefit your business. By following this detailed tutorial, you can create an efficient WhatsApp chatbot that enhances customer engagement and improves response times.
