To start integrating Magic Bricks with Zoho CRM, you first need to access Pabbly Connect. Begin by visiting the Pabbly website at pabby.com. If you are a new user, you can sign up for a free account, which provides 100 tasks per month. This allows you to test the platform’s features before committing to a paid plan.
Once you have signed up or logged in, navigate to the Pabbly Connect dashboard. Here, you will see options to create workflows. Click on the “Create Workflow” button to start setting up your integration. This is where Pabbly Connect will facilitate the connection between Magic Bricks and Zoho CRM.
In this section, we will create a new workflow specifically for integrating Magic Bricks with Zoho CRM. After clicking on “Create Workflow”, name it “Real Estate Automation: Magic Bricks to Zoho CRM”. Select a folder for organization, and click on “Create” to proceed.
- Name your workflow clearly for easy identification.
- Choose a relevant folder to keep your workflows organized.
Once the workflow is created, you will be prompted to set up a trigger application. Here, select Magic Bricks as your trigger app. This means that every time a new lead is received from Magic Bricks, the workflow will be activated, showcasing how Pabbly Connect manages the automation process.
3. Setting Up the Trigger with Magic Bricks
Now, let’s focus on setting up the trigger in Pabbly Connect. Choose the event “New Leads” from Magic Bricks. This event will initiate the workflow whenever a new lead comes in. After selecting the event, click on “Connect” to establish a connection between Magic Bricks and Pabbly Connect.
To complete the connection, a webhook URL will be generated. This URL acts as a bridge between Magic Bricks and Pabbly Connect. You will need to provide this URL to your Magic Bricks account manager, as the platform does not allow direct user interface configuration for webhooks.
- Select “New Leads” as the trigger event.
- Copy the provided webhook URL and send it to your account manager.
Once the connection is set up, click on “Capture Webhook Response”. This will allow you to see the lead details being captured by Pabbly Connect. Ensure you receive a response to confirm that the integration is functional.
4. Setting Up Zoho CRM as the Action Application
Now that the trigger is established, we will set up Zoho CRM as the action application in Pabbly Connect. Choose Zoho CRM and select the action event “Create or Update Record”. This action will ensure that every new lead captured from Magic Bricks is automatically added to Zoho CRM.
When prompted, connect your Zoho CRM account by entering your domain (e.g., zoho.in) and authorizing Pabbly Connect to access your Zoho account. This step is crucial for allowing data transfer between the two platforms.
- Select “Create or Update Record” as the action event.
- Enter your Zoho domain for proper connection.
After connecting, you will need to map the fields from the Magic Bricks lead response to the corresponding fields in Zoho CRM. This ensures that the data is accurately transferred and recorded in your CRM system, demonstrating the efficiency of Pabbly Connect in managing lead information.
5. Mapping Fields and Testing the Integration
In this final section, we will map the fields from the Magic Bricks lead response to the Zoho CRM fields. This step is crucial as it ensures the data from new leads is accurately captured in the correct fields. For instance, you will map the lead’s first name, last name, email address, and phone number to their respective fields in Zoho CRM.
Once you have completed the mapping, click on “Save and Send Test Request” to test the integration. If successful, you should see the new lead appear in your Zoho CRM under the leads section. This confirms that Pabbly Connect has successfully facilitated the integration between Magic Bricks and Zoho CRM.
- Map all necessary fields accurately.
- Test the integration to ensure data flows correctly.
With this setup, you can now efficiently manage your real estate leads using Pabbly Connect, enhancing your workflow and ensuring that all leads are captured seamlessly into your CRM.
In this tutorial, we demonstrated how to integrate Magic Bricks with Zoho CRM using Pabbly Connect. This integration allows you to automate lead management, ensuring that all new leads are captured efficiently. By following these steps, you can enhance your business operations and improve your lead tracking process.
