1. Accessing Pabbly Connect and Pabbly Chat Flow
To begin integrating WhatsApp with Pabbly Connect, first, navigate to Pabbly Connect by entering pabbly.com/chatflow in your browser. This will lead you to the homepage of Pabbly Chat Flow, where you can sign up for a free account or log in if you’re an existing user.
Once logged in, you will see all Pabbly applications. Click on the ‘Access Now’ button for Pabbly Chat Flow. Here, you can connect your WhatsApp number, which is essential for sending broadcasts. If you need help connecting your number, tutorials are available on the Pabbly YouTube channel.
2. Creating a Message Template in Pabbly Chat Flow
Before sending bulk messages, you need to create a message template in Pabbly Chat Flow. This template will be used for your WhatsApp broadcasts. Navigate to the template section to create and manage your message templates.
- Create a new template and ensure it’s approved by Meta.
- Add any images or specific content you want to include in your message.
- Make sure to save your template for future use.
Once your template is approved, you can easily select it when setting up your broadcast. This ensures a professional appearance and compliance with WhatsApp’s messaging policies.
3. Setting Up Your WhatsApp Broadcast Using Pabbly Connect
Now that you have your template ready, it’s time to set up the WhatsApp broadcast through Pabbly Connect. Go to the broadcast section and click on the ‘Create New Broadcast’ button. Select ‘Broadcast Campaign’ as the type.
- Name your broadcast (e.g., ‘New Offer’).
- Choose your audience from existing contact lists or upload a CSV file with customer details.
- Select the message type: either a pre-approved template or a regular message.
After setting these options, you can personalize your message further by adding variables. This allows you to tailor the broadcast to individual customers, enhancing engagement and effectiveness.
4. Testing and Scheduling Your Broadcast with Pabbly Connect
Before going live, it’s crucial to test your broadcast to ensure everything works smoothly. Use the test feature in Pabbly Connect to send a test message to your WhatsApp number.
If the test is successful, you can then schedule your broadcast. Decide whether to send the message immediately or schedule it for a later date and time. Make sure to choose a future date to avoid sending it instantly.
Additionally, you can enable automatic retries for failed messages, ensuring that your broadcast reaches all intended recipients. This feature is especially useful for maintaining engagement with your audience.
5. Monitoring Broadcast Results in Pabbly Connect
After your broadcast has been sent, you can monitor its performance directly from Pabbly Connect. Check the statistics for sent, delivered, read, and failed messages to evaluate the effectiveness of your campaign.
If some messages fail, you have the option to resend them easily. This feature allows you to maintain contact with customers who may have missed your initial broadcast, ensuring your offers reach as many people as possible.
By utilizing the analytics provided by Pabbly Connect, you can refine your future broadcasts for better engagement and response rates.
In this tutorial, we explored how to use Pabbly Connect to integrate WhatsApp for broadcasting messages effectively. By following these steps, you can streamline your communication with customers and enhance your marketing efforts.
