1. Accessing Pabbly Chatflow for WhatsApp Automation
To start automating WhatsApp messages, you need to access Pabbly Chatflow. Begin by visiting the Pabbly Chatflow landing page at pavly.com/chatflow. This platform allows you to automate WhatsApp conversations without any coding skills.
Once on the page, you’ll see options to sign in or sign up. If you’re a new user, click on the “Sign up for free” button to create an account, which gives you 100 free tasks each month. Existing users can simply log in. After logging in, navigate to the Pabbly Chatflow dashboard to begin your WhatsApp messaging automation.
2. Connecting Your WhatsApp Number to Pabbly Chatflow
Integrating your WhatsApp number is crucial for using Pabbly Chatflow. On the dashboard, locate the “Add WhatsApp Number” button. This step is essential as it allows Pabbly Chatflow to send messages directly to your customers.
  • Click on the “Add WhatsApp Number” button.
  • Follow the prompts to connect your WhatsApp account.
  • Ensure your number is verified to use all features.
After connecting your number, you can start using Pabbly Chatflow for your WhatsApp marketing campaigns. Make sure to follow the instructions carefully to avoid any issues during the setup process.
3. Creating Broadcast Messages in Pabbly Chatflow
Now that your WhatsApp number is connected, it’s time to create broadcast messages using Pabbly Chatflow. Navigate to the “Broadcast” section on your dashboard. Here, you can manage all your broadcast campaigns and create new ones.
To create a new broadcast, click on the “Add Broadcast” button. You will need to select the type of broadcast campaign. Choose between a “Broadcast Campaign” and an “API Campaign” depending on your needs. For this tutorial, select the “Broadcast Campaign” option.
  • Name your broadcast (e.g., “New Product Launch”).
  • Select the contact list you want to send the messages to.
  • Choose the message type (text or media).
After setting these parameters, you can proceed to customize your message and send it to your customers using Pabbly Chatflow.
4. Uploading Contacts from Google Sheets
To effectively use Pabbly Chatflow, you may want to upload customer contacts from Google Sheets. First, ensure your contacts are saved in a CSV format. You can download your Google Sheets as a CSV file by selecting “File” > “Download” > “Comma-separated values (CSV)”.
Once you have the CSV file ready, go back to the “Add Contacts” section in Pabbly Chatflow and select the option to add bulk contacts. Upload your CSV file by clicking on the “Upload Files” button and selecting the CSV file from your computer.
  • Click on “Add Bulk Contacts”.
  • Select your CSV file and upload it.
  • Confirm the upload to add contacts to your list.
After uploading, you can select this list when creating your broadcast messages in Pabbly Chatflow, ensuring you reach all your customers efficiently.
5. Sending Test Messages and Scheduling Broadcasts
Before finalizing your broadcast, it’s essential to test your message. In Pabbly Chatflow, enter a sample name and phone number to send a test message. This ensures that your message appears correctly for your customers.
Once you confirm that the test message is sent correctly, you can set your broadcast to be sent immediately or schedule it for later. To schedule, select the option to schedule for later, and choose the date and time for your broadcast.
  • Select the date and time for your broadcast.
  • Click on the “Add Broadcast” button to save your settings.
  • Confirm that your broadcast is scheduled as intended.
With this, you can send personalized WhatsApp messages to multiple customers at once using Pabbly Chatflow, enhancing your marketing efficiency.
This tutorial demonstrated how to automate WhatsApp messaging using Pabbly Chatflow. By connecting your WhatsApp number, uploading contacts, and creating broadcast messages, you can efficiently reach your customers with personalized content. Start utilizing Pabbly Chatflow today to streamline your WhatsApp marketing efforts.
