To begin the integration of WhatsApp with Pabbly Connect, you need to access the Pabbly website. Simply type Pabbly Connect in your browser and navigate to the homepage. If you’re a new user, click on “Sign Up for Free” to create an account and start your free trial.
If you’re an existing user, sign in to your account. Once logged in, you will see various applications offered by Pabbly. Click on the “Access Now” button for Pabbly Chatflow, which is essential for managing WhatsApp communications.
2. Setting Up WhatsApp Broadcast in Pabbly Connect
After accessing Pabbly Connect, you need to set up a WhatsApp broadcast to send bulk messages. Navigate to the broadcast section in the dashboard. Here, you can create a new broadcast campaign by clicking the “Add Broadcast” button.
- Select the campaign type as “WhatsApp Broadcast”.
- Name your campaign, e.g., “Sale Alert”.
- Choose the contact list you want to send the messages to.
Make sure to have your contacts uploaded in Pabbly Connect. You can import contacts from a CSV file or manually add them. This step is crucial for reaching your audience effectively.
3. Creating a Message Template for WhatsApp
Next, you need to create a message template for your WhatsApp broadcast. This template will contain the message you wish to send out. In the Pabbly Chatflow, navigate to the templates section and click on “Create Template”.
Fill in the required fields, including the message body. You can personalize your message by using variables such as names. Make sure to save your template once you’re done. This template will be used in your broadcast campaign.
4. Testing and Scheduling Your WhatsApp Broadcast
Before sending your broadcast, it’s important to test the message. In the broadcast window, you can see an option to send a test message to your phone. Click on “Send Test Message” to ensure everything appears correctly.
If the test is successful, you can proceed to schedule your broadcast. Choose whether to send it immediately or at a later date. Ensure you select a future date and time for scheduling.
- Select the date and time for your broadcast.
- Click on “Schedule Broadcast” to finalize the setup.
Once scheduled, you can monitor the status of your broadcast from the dashboard.
5. Monitoring Broadcast Results in Pabbly Connect
After your broadcast is sent, you can track its performance directly in Pabbly Connect. Navigate to the broadcast section to view various metrics such as sent, delivered, and pending messages.
This information will help you understand the effectiveness of your campaign. You can resend the broadcast if necessary or make adjustments based on the results. Utilize this feedback to improve future campaigns.
In this tutorial, we explored how to integrate WhatsApp with Pabbly Connect for effective bulk messaging. By following these steps, you can streamline your communication and engage with customers efficiently.
