To start creating your WhatsApp broadcast campaign, first access Pabbly Chatflow by navigating to the Pabbly website. This powerful tool helps automate WhatsApp messaging efficiently.
If you are new to Pabbly, click on the ‘Sign Up Free’ option to create your account. This will give you access to 100 free credits every month, perfect for testing your campaigns.
2. Adding Your WhatsApp Number in Pabbly Chatflow
After signing in, the next step is to add your WhatsApp number to your Pabbly Chatflow account. This is essential for sending messages through the platform.
- Navigate to the settings menu.
- Select the option to add a new WhatsApp number.
- Follow the prompts to verify your number.
Once your number is added, you can access the broadcast feature from the left-hand menu. This feature allows you to send WhatsApp messages to a predefined list of contacts without getting banned.
3. Creating a Broadcast Campaign in Pabbly Chatflow
To create a new broadcast in Pabbly Chatflow, click on the ‘Add Broadcast’ button. This will take you to the campaign setup page where you can customize your message.
- Select the type of broadcast campaign.
- Name your broadcast (e.g., “Season Finale Sale”).
- Choose your contact list.
After naming your campaign, you can refine your audience by excluding certain contacts if needed. This allows for a targeted approach in your messaging strategy.
4. Uploading Contacts to Pabbly Chatflow
The next step is to upload your contacts to Pabbly Chatflow. You can do this by navigating to the contacts feature and selecting ‘Add Contacts’.
- Choose to upload contacts in bulk using a CSV file.
- Ensure your CSV file includes first name, last name, and phone number.
- Upload the file and click ‘Insert’ to add your contacts.
With your contacts uploaded, you can now proceed to schedule your broadcast campaign. This is where Pabbly Chatflow truly shines, allowing you to reach thousands of customers simultaneously.
5. Scheduling Your WhatsApp Broadcast Using Pabbly Chatflow
Once your contacts are in place, it’s time to schedule your broadcast in Pabbly Chatflow. You can choose to send the message instantly or schedule it for a later date.
To schedule, select the date and time for your broadcast. For example, you might set it for May 28th at 5:00 PM. After confirming your schedule, click on the ‘Add Broadcast’ button to finalize.
Finally, you can view the stats of your broadcast and track its performance. This feature in Pabbly Chatflow allows you to see delivery rates, read statuses, and even resend messages to failed contacts.
In this tutorial, we explored how to create a WhatsApp broadcast campaign using Pabbly Chatflow. By following these steps, you can effectively engage with your customers and enhance your marketing efforts.
