To start integrating Google Blogger with Facebook, you need to access Pabbly Connect. Visit the Pabbly Connect website at www.pabbly.com/connect. Once there, you can sign up for a free account, which provides you with 100 free tasks every month.
If you’re logging in for the first time, ensure to complete the signup process. After logging in, you can begin setting up your automation workflow to share your Google Blogger posts on your Facebook page automatically.
2. Setting Up the Trigger for Google Blogger
In this section, we will configure the trigger in Pabbly Connect to detect new posts on Google Blogger. Start by selecting the “Google Blogger” app and choose the trigger event as “New Post Added.” This will initiate the workflow whenever a new blog is published.
Next, you need to create a connection to your Google Blogger account. Follow these steps:
- Click on “Add New Connection” and sign in with your Google account.
- Select the Google Blogger account that manages your blog.
- Grant the necessary permissions to Pabbly Connect.
After successfully creating the connection, you can specify which blog ID and status you want to monitor. Make sure to choose the option to capture only live posts, ensuring only published vlogs trigger the automation.
