To start automating your Google Blogger posts to Facebook, first access Pabbly Connect. Open your browser and type in pabbly.com/connect. This will take you to the Pabbly Connect landing page.
If you are a new user, click on the “Sign Up for Free” button to create your account. Existing users can simply click on “Sign In” to access their dashboard. Once logged in, you can begin creating your automation workflows.
After logging into Pabbly Connect, you will be directed to the dashboard. Here, click on the “Create Workflow” button to start a new automation. You can choose to build from scratch or use the AI feature to generate a workflow.
- Select the trigger application as Google Blogger.
- Set the action application to Facebook.
Once you have selected your applications, click on “Create” to proceed. This will set up the foundation for your automation.
3. Connecting Google Blogger to Pabbly Connect
To connect Google Blogger, click on the “Connect” button in your workflow. You will be prompted to add a connection. Select “Add New Connection” and then choose “Sign In with Google” to authenticate your Google account.
After signing in, select the specific blog you want to automate. Ensure that you set the status to “Only Live” to capture only the published posts. Click on “Save and Send Test Request” to verify the connection. Pabbly Connect will now poll Google Blogger for new posts.
4. Sharing Blogger Posts on Facebook
Now that Google Blogger is connected, it’s time to set up the Facebook integration. Click on the “Connect” button again, and this time select “Connect with Facebook Pages”. You will need to log into your Facebook account and choose the page where you want to share your posts.
- Type your message for the Facebook post.
- Map the URL of your blog post from the previous step.
- Ensure the link is dynamic to capture future posts automatically.
Once you have filled in the necessary fields, click on “Save and Send Test Request”. This will send your blog post to the selected Facebook page, confirming that your automation is functioning correctly.
5. Conclusion: Automate Your Social Sharing with Pabbly Connect
Using Pabbly Connect to automate sharing your Google Blogger posts on Facebook enhances your online presence. By following these steps, you can ensure that every new blog post reaches a wider audience effortlessly.
With the seamless integration between Google Blogger and Facebook via Pabbly Connect, you can focus more on creating content while your automation takes care of the sharing process. Start using Pabbly Connect today to boost your blogging efficiency!
