1. Accessing Pabbly Connect for Product Promotions
To start using Pabbly Connect for your product promotions, first visit the Pabbly Connect website. Sign up or log in to your account. This platform is essential for integrating your WhatsApp messaging with your product launch notifications.
Once logged in, you can navigate to the dashboard, where you will find various options to set up your integrations. Pabbly Connect simplifies the process of sending bulk messages without risking account bans, making it the ideal choice for your marketing strategy.
2. Creating Contact Lists in Pabbly Connect
Creating a contact list is crucial for sending bulk messages through Pabbly Connect. In your Pabbly Chartflow account, go to the contacts section and click on the plus button to add new contacts. This step ensures that you have all your customers organized and ready to receive messages.
  • Click on the “Add Contact” button.
  • Enter customer details including names and phone numbers.
  • Save the list to use in your broadcasts.
After creating your contact list, you can easily select it when setting up your broadcast messages. This organization is vital for effective communication with your audience.
3. Setting Up Template Messages Using Pabbly Connect
Next, you need to create a template message for your product launch using Pabbly Connect. Navigate to the template section and click on the create button. This template will be the message that your customers receive during the promotional campaign.
Make sure to include engaging content in your template. You can add images and promotional text to attract your customers. Once created, the template will be submitted for approval, which is necessary before you can use it for broadcasts.
  • Choose a name for your template.
  • Upload an image related to the product.
  • Submit for Meta approval.
Once approved, you can use this template in your broadcasts, ensuring that your messages are both visually appealing and compliant with WhatsApp’s guidelines.
4. Scheduling Broadcasts with Pabbly Connect
To send your promotional messages, you will need to schedule a broadcast using Pabbly Connect. Go to the broadcast section and click on “Add Broadcast”. Here, you can select the type of broadcast campaign you want to run.
After naming your broadcast, choose your audience from the contact list you created earlier. You can refine your audience by excluding certain contacts if necessary. Once your audience is set, select your template message and upload any additional images.
  • Select the broadcast type as “Campaign”.
  • Enter the broadcast name.
  • Choose the date and time for sending the broadcast.
Once you’ve set everything up, click on “Schedule” to confirm the broadcast. This feature allows you to plan your marketing efforts ahead of time, ensuring timely communication with your customers.
5. Testing Your Broadcasts Through Pabbly Connect
Before you send out your promotional messages, it’s essential to test your broadcasts using Pabbly Connect. You can enter your details in the test section to see how the message will appear to your customers. This step ensures that everything looks perfect before the actual launch.
After sending a test broadcast, check your WhatsApp to confirm that the message appears as intended. This testing phase is crucial for identifying any issues early on.
  • Enter your name and phone number in the test section.
  • Click on “Send Test” to receive the message.
  • Review the message for any errors.
Once you are satisfied with the test results, you can proceed to launch your campaign confidently, knowing that your messages will reach your customers effectively.
This tutorial demonstrates how to use Pabbly Connect for integrating WhatsApp to send bulk product promotions. By following these steps, you can effectively communicate product launches to your customers, ensuring a successful marketing strategy.
