1. Accessing Pabbly Chatflow for WhatsApp Marketing
To start using Pabbly Chatflow, open a new tab and navigate to pabbly.com/chatflow. If you’re not a current user, create an account to receive 100 free credits each month. This allows you to explore the platform effectively.
Once logged in, you can access the broadcast feature of Pabbly Chatflow. This feature is essential for creating WhatsApp marketing campaigns tailored to various business needs.
2. Creating a Broadcast Campaign in Pabbly Chatflow
To create a new broadcast campaign in Pabbly Chatflow, click on the “Add Broadcast” button. You will then select the type of broadcast, which in this case is a “Broadcast Campaign”. Enter a name for your broadcast, such as “Custom Print Requests Campaign”.
  • Choose existing contact lists or upload a CSV file.
  • Select the audience for your campaign.
  • Utilize the contact feature to manage your lists within Pabbly Chatflow.
After naming your broadcast, you can either select an existing contact list or upload a CSV file containing your contacts. This flexibility allows you to target specific audiences effectively.
3. Optimizing Your Audience in Pabbly Chatflow
In this step, you can optimize your audience by excluding contacts you do not wish to receive messages. You can select those contacts from the dropdown menu provided in Pabbly Chatflow. Additionally, you can activate an option to skip contacts who have messaged you in the last 24 hours.
To enhance your campaign further, you can also consider the following options:
  • Exclude specific contact lists from receiving messages.
  • Skip contacts who have recently engaged with you.
This audience optimization feature in Pabbly Chatflow ensures that your messages reach the right people at the right time, maximizing engagement.
4. Selecting Message Type for Your Campaign
Choosing the right message type is crucial for your campaign’s success. In Pabbly Chatflow, you can select between a template message or a regular message. Template messages are essential for initiating conversations outside of the 24-hour messaging window.
To select a template message, simply choose a WhatsApp template from the options available. You can customize your message by adding images or additional content as needed. For instance, you might select a template for custom print requests and add an image relevant to your campaign.
5. Testing and Scheduling Your Broadcast in Pabbly Chatflow
Before launching your campaign, it’s important to test your broadcast. Enter a test contact name and number, then click on the “Send Test Message” button. This allows you to verify that your message appears correctly on WhatsApp.
If the test is successful, you can schedule your broadcast. In Pabbly Chatflow, you can choose to send the message immediately or schedule it for a later date. For example, you can set it for October 26th at 10:00 AM. Additionally, you can enable automatic retries for contacts that did not receive the message initially.
Once everything is set, click on the “Create Broadcast” button to finalize your campaign. You will now see your scheduled broadcast listed in Pabbly Chatflow.
In this tutorial, we explored how to set up a WhatsApp marketing campaign using Pabbly Chatflow. By following these steps, you can effectively promote your business and engage with customers directly on WhatsApp. Utilize Pabbly Chatflow for seamless integration and powerful marketing capabilities.
