1. Accessing Pabbly Connect for WhatsApp Broadcasting
To begin using Pabbly Connect for WhatsApp broadcasting, first visit Pabbly Connect by navigating to pabbly.com/chatflow. This will lead you to the Pabbly Chat Flow homepage. If you are a new user, click on the “Sign Up Free” button to create an account. Existing users should log in to access their dashboard.
Once logged in, locate the Pabbly Chat Flow application under the Pabbly suite. Click on “Access Now” to enter your Pabbly Chat Flow dashboard. Ensure you have linked your WhatsApp number within your Chat Flow account to proceed with the broadcasting setup.
2. Creating a Broadcast in Pabbly Chat Flow
After accessing your Pabbly Chat Flow dashboard, the next step is to create a broadcast. Navigate to the “Broadcast” section where you will see the total number of broadcasts and messages sent. To start a new broadcast, click on the “Add Broadcast” button.
  • Select the broadcast type as “Campaign Broadcast”.
  • Name your broadcast, for example, “New Wholesale Offer”.
  • Choose your audience from existing contacts or upload a CSV file.
For this tutorial, I will use an existing contact list. You can also upload a CSV file if your data is in Google Sheets. After selecting your audience, you can optimize your audience by excluding contacts that should not receive the message.
3. Setting Up the Message Template in Pabbly Chat Flow
With your broadcast set up, the next step is to create the message template. In Pabbly Chat Flow, navigate to the “Templates” section to view existing templates. Here, you can select a pre-approved template or create a new one. Make sure your template is visually appealing and compliant with WhatsApp’s guidelines.
To create a new template, click on “Create Template” and fill in the required fields. Include text, images, and any other media to enhance your message. Ensure that your template is approved by Meta for WhatsApp broadcasting. Once your template is ready, select it for your broadcast.
4. Testing and Scheduling Your Broadcast
Before sending your broadcast, it is crucial to test the message. Pabbly Connect allows you to send a test message to your WhatsApp number. Click on the “Send Test Message” button to verify the message format and content.
After testing, you can schedule your broadcast. Decide whether to send it immediately or at a later date. If scheduling, select the date and time carefully, ensuring it is in the future. Activate automatic retries for any failed messages to ensure successful delivery.
5. Viewing Performance Metrics in Pabbly Connect
Once your broadcast is sent, you can monitor its performance through Pabbly Connect. Navigate to the broadcast statistics section to view metrics such as messages sent, delivered, read, and failed. This will help you assess the effectiveness of your campaign.
If any messages failed to send, you can use the “Resend” option to attempt to deliver them again. This feature ensures that your promotional messages reach your audience successfully. Analyzing these metrics will provide insights for future campaigns.
In summary, using Pabbly Connect for WhatsApp broadcasting allows you to efficiently reach your audience with promotional messages. By following the steps outlined above, you can leverage the power of Pabbly and Pabbly Chat Flow to enhance your communication strategy.
