1. Accessing Pabbly Connect for WhatsApp Broadcasts
To start using Pabbly Connect for creating WhatsApp broadcasts, first navigate to the Pabbly Chatflow website. You can do this by entering pavly.com/chatflow in your browser.
Once on the Pabbly Chatflow landing page, click on the “Sign Up Free” button to create your account. This will give you access to 100 free credits every month, allowing you to start using the platform without any initial investment.
2. Creating Your WhatsApp Broadcast
After signing in to your Pabbly Chatflow account, locate the “Add Broadcast” button on your dashboard. This is where you will start creating your broadcast campaign.
  • Click on the “Add Broadcast” button to begin.
  • Select “Broadcast Campaign” from the dropdown menu.
  • Name your broadcast, for instance, “New Property Launch Broadcast”.
Next, choose the contact list to which you want to send the broadcast. This can be done from the dropdown menu in the contact list section. Ensure that you have a contact list created beforehand to make this process seamless.
3. Refining Your Audience for the Broadcast
In this step, Pabbly Connect allows you to refine your audience by excluding certain contacts or lists. This feature is crucial for targeted marketing.
  • Select the option to exclude contact lists if necessary.
  • You can also exclude specific contacts from your selected list.
After refining your audience, proceed to select the message type. You can choose between a pre-approved template message or a regular message. For broader reach, it’s advisable to go with the pre-approved template message.
4. Sending and Testing Your Broadcast
Once you have set the message type, you can draft your message using dynamic fields. For example, you can personalize the message by including the customer’s name using a dynamic field format.
To test your broadcast, enter your own details in the test message section and click the “Send Test Message” button. This will allow you to verify that the message is formatted correctly before sending it out to your entire contact list.
5. Scheduling Your Broadcast for Delivery
With Pabbly Connect, you have the option to either send your broadcast immediately or schedule it for later. If you choose to schedule, select the date and time you wish to send the broadcast.
After setting the desired schedule, click the “Add Broadcast” button to finalize the scheduling. You will receive a confirmation that your broadcast is set for the specified date and time.
Using Pabbly Connect to create WhatsApp broadcasts is an effective way to reach your audience instantly. With the steps outlined in this tutorial, you can easily set up and manage your broadcasts for any event or promotion.
